ucd 25 watts to 1200 watts using 2 mosfets
Old 2nd September 2012, 08:49 PM   #2491
red_zone003 is offline red_zone003  Romania
And here is the pcb of the second amp posted by Exflaco...and the hungarian page: Gyakorlati építési tanácsok - 600W-os D osztályú végfok - Hobbielektronika.hu - online elektronikai magazin és fórum
Old 2nd September 2012, 09:31 PM   #2492
exflaco is offline exflaco  Armenia
Tanks red_zone003 y forgot the site tanks a lot
Old 2nd September 2012, 11:52 PM   #2493
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default ocp
Andrew OCP Detex same the Crest class D amps ,Lm311 and 555 ,triell ,more simple a npn transistor and 555 two work fine ,a lot similar protecction on class d amps you only parallel 3 X1 ohms 5w resistor paraleel , and adjust the trimp to the desired humbrall protecttion,(sorry my poor english) more efficient + and - v sense ,another way old AB amps like Peavey the shunt sense resistor to gnd series to the speaker,y share schemm soon..
Hi Exflaco
greetings thank you for replying and more important the COOPERATION i appreciate your efforts thanks
warm regards
andrew
"It's Better to try and fail than to never know and always wonder"
Old 3rd September 2012, 06:23 AM   #2494
manojtm is offline manojtm  India
manojtm's Avatar
hi mano will your old design work comfortably with irfp250 at +/- 75vlts with 2ohms load
Hi stewin,
don't use my old design
regards
MANOJ
Old 5th September 2012, 11:08 PM   #2495
binho is offline binho  Brazil
could you post the next button
wanted montalo
thank you
fabio de manaus
Old 8th September 2012, 08:14 AM   #2496
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay ucd 25 watts to 1200 watts using 2 mosfets
Default limiter corrections
Originally Posted by irvynejay View Post
Ok here we go with fix
Sorry i see something wrong
and fixed
File Type: pdf limeter with buffer in balance input bottom.pdf (54.5 KB, 583 views)
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 8th September 2012, 09:52 AM   #2497
don2007ksa is offline don2007ksa  Philippines
limiter with buffer,thank's to irvynejay
Old 8th September 2012, 09:57 PM   #2498
Tanks Irvynejay coud tell my wo ist this design?
Old 9th September 2012, 02:10 AM   #2499
irvynejay's Avatar
Exflaco its my awful poor not tested design
Old 9th September 2012, 02:52 PM   #2500
Default bridge designs
Could you share, i test it, look very good wat its awfull poor its nice design .You similate it?
Another good design bridge
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
