Go Back   Home > Forums > Amplifiers > Class D
Old 19th January 2012, 04:56 PM   #1601
akraj is offline akraj  Bangladesh
hmmm.....I know it is comparatively complex but it includes end to end design; surely this is tested and will be stable. I was searching for sub amp so it will serve my purpose. HOwever, CPX do you have any working amp design? would be greatful if you can share that!
Old 19th January 2012, 07:49 PM   #1602
CPX is offline CPX  Romania
There are a several working designs on this thread..if you want you can choose one..my amplifier also works and i have made lots of tests but i am still working on improuvements so i have no final schematic yet..
Old 22nd January 2012, 04:50 AM   #1603
Okay CPX, what do you think about the JBL schematic? I will try to draw a PCB if this is praiseworthy
Old 22nd January 2012, 07:45 PM   #1604
That schematic is for low frequencies only..there are so many others you can use..,what is your experience level..have you worked with switching mode power supplies before ?if so there you will be capable to use any schematic not just blindy copy one.
Old 31st January 2012, 12:12 PM   #1605
manojtm is offline manojtm  India
manojtm's Avatar
Hi All
Now I will give my working design!!!!!!!!!!!!!!!
Its simple and good.Protection and all other things can added later
Old 31st January 2012, 01:20 PM   #1606
manojtm's Avatar
Hi All
In my schematic op-amp shows LM1458 its LM358. If you use LM1458 supply must be +12V & -12V
Old 31st January 2012, 01:33 PM   #1607
manojtm's Avatar
Everybody says that quality of the Class D amp is depending on freq.
Class D amp will work 60KHz to 500KHz but you should use proper supporting components.
The advantage of increasing freq. reducing the size of filter coil and capacitor
Old 2nd February 2012, 06:18 PM   #1608
stewin is offline stewin  Kenya
hi manojtm did you use 500khz with irfp250 at +/-75vlts? did it work and what load did you use 8ohms 4ohms or was it stable at 2ohms ? thanks for sharing.
Old 4th February 2012, 11:00 AM   #1609
manojtm's Avatar
Hi stewin IRFP250 will not support 500KHz . 250KHz is Max. It will hot.125KHz is normal and stable @2ohm load
If you want to set 500KHz ,use IRFB4227
Old 6th February 2012, 01:43 PM   #1610
andrewlebon's Avatar
Default MOSFET RECOMENDATIONS
Hello
greetings can any one advice me which is most suitable mosfet for this amp
i am using IRF250 on50 volt dc rails
1 IRFB4103Pbf
2 IRFB 4227BPbf
data sheet of IRFB4103 shows Rds on@10 volts 139Mohm
data sheet of IRFB4227 shows Rds on@10 volts 19.7Mohm
can anyone advice me most suitable mosfet
warm regards
andrew lebon
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 44 3rd April 2013 02:57 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2013 diyAudio
