Audiom | 100-W audio amp is 20 times more efficient than Class D chips
20 times more efficient? Gee, worst-case class-D is 70% efficient, so this thing must be 1400% efficient! Call the Nobel Prize committee, we've discovered the secret of endless power!
That's what happens when you let the marketing pukes put out a press release before the engineers fact-check it.
No, I think it's a real chip. From what I can gather it's a class D driver chip with an on-board look-ahead SMPS. The SMPS steps up the 1.5V to whatever rails are needed by the class D amp to output the signal and then the class D drivers have their losses minimized by only switching the voltage needed (rather than required full power rails) and also due to longer on-times. All the power devices are off chip. This is just a controller.
I'm sure it's really good for a wristwatch boom box but that 100W spec has some very specific conditions on it. It sure as hell ain't gonna run no 15" subwoofer off a AA battery.😉
They could increase the voltage out with a switching reg type cct (isnt this what class D is) (12v car amps can put out 1000w) but which pin is the 100amps going thru?
They talk about "small batteries", wich cannot offer 100 watts, not even in 20msec burst,and that's for an 100% randament!
That's a LIE, or, maybe they have discovered, new phisic laws...😱
To me it seems to be targeted at cheap boom boxes. The title 25 times more efficient than class-d is just marketing ** used as eyecatcher. What they do is achieving less IDLE losses than class-d. Which can not be neglected in battery powered applications that are just used for background listening.
On the circuit board pictured one doesn't see an output filter. Maybe it is a linear amp with a highly efficient PSU. Maybe it is a filterless class-d amp - in this case it is definitley targeted at cheap crappy products.
Charles
I think it's a mix of several technologies. Feed forward switching supply, filterless output, probably also some sound processing to filter out less dominant frequncies and emphasize dominant frequencies.
Definitely targeted at ultra-low end sound (think integrated speakers in mobile phones here). But still "20 times more effecient than class-D"? Load of **! The Tripath 2020 uses ~55mA in idle, or about twice as much a normal power LED, so if you include one you have raised the power consumption by 50%.
For something that is (almost) idle more than 98% of the time there are definitley solutions that offer additional reduction of wasted power than ordinary class-d.
I don't think this chip is targeted at lowest-power applications like mobile phone but at boom boxes.
BTW: Really LOW power applications like mobile-phones and hearing aids are the areas that are mainly class-d nowadays. I was attending a class-d conference recently. A lot of topics covered small integrated class-d amps for mobile phones etc.
Charles
Defineatly cheap aps. Maybe integrated on board PC sound, iPods, etc.
Rather interesting claims, though, and I agree that it is probably some
combinations of various technologies and may be indeed a bit more
efficient than Class D (but nowhere near the claims). I don't want to
buy any yet. But if somebody else wants to experiment in small amps,
it would be nice to have them give us results.
I'm not going to believe it at all until I can get the datasheets. And I won't fully believe it until I actually have one to play with. I'll power it with some supercaps and solar cells for the ultimate smug experience.
Actually, I'll power it with some CoolChips ( http://www.coolchips.gi/ ) running in reverse. (Unlike solar cells, a custom machined copper rod thermal collector will work indoors in total darkness, but would be very awkward to use outdoors. So solar cells for outdoors, thermal collector for indoors.)
Class D efficiency
Class D amplifiers are NOT 70% efficient or anything close.
A class D amplifier at idle is 0% efficient.
A class d amplifier at clip into a load which does not push the RDs on to its limits is 90%+ efficient BUT with a sine wave....last time I looked nobody was actually listening to sine waves.
So the typical efficiency of a class D amplifier with average music into a reasonable load with the musical peaks just at clipping is well below 70%
Drive your class D with pink noise at 1/8 of rated power = typical program material with occasional clipping and then measure the efficiency and post that result
Read all the info, before trashing the chip. The 20 times more efficient is at low levels.
I do NOT know any class-D with 70% efficiency at low levels, since the "household-consumption" in the amp typiclly consumes some watt's. And at ex 0,1 watt output, the efficiency is very low.
