Go Back   Home > Forums > Amplifiers > Class D
Old 23rd September 2008, 02:57 AM   #51
Originally posted by Eva
Put a capacitor across the filament, an inductor in series and apply a square wave. The waveform at the filament will be sine like. You will have to choose component values carefully so that the LC filter removes enough high frequency components and the filament resistance when hot provides enough damping to the filter. That's all. Electronic ballasts for fluorescent lamps work much in the same way.
If I were doing a filament supply from scratch, yeah like you said...
I assume you mean something like Pete Millet's design? I do not
have those sort of ballast drivers readily overflowing my bench.
I got buckets of prototype Class-D's that for one reason or other
weren't deemed perfect enough to ship, but might still light up an
old transmitter tube or two? I hate seeing them go to waste. The
alternative is to destroy them some other way. They can't leave,
and I got far more than I can ever use for "normal" test purposes.
Even if this works, I probably couldn't show you anything but the
filaments without permission... Kinda pointless experiment really.
I'm just a pass/fail production test monkey with a procedure to
follow. Not any sort of an actual engineer yet. Some of my own
ideas are far-out and half-baked to say the least. They don't give
me a lot of spare time to do any real damage.
Old 8th October 2008, 07:56 PM   #52
FUCHSAUDIO's Avatar
Send a message via AIM to FUCHSAUDIO Send a message via Yahoo to FUCHSAUDIO
Default IC question
Originally posted by Möter
Hello guys,
I want to have some TPA3122 pcb's professionally made.
The TPA3122 is in BTL configuration and used in combination with a THS4131 fully differential opamp in order to perform single ended to balanced conversion.
Because I'm quite new to electronics I'd like to have experienced people to take a look at my schematic and future board layout, before I spend money on boards that won't work in a desirable fashion.
Also: should I connect the power ground of the 24V for the amp with the power ground of the +-15V for the opamp?
The schmematic is attached. Thanks in advance for your advice.
What is the chip you are using as the phase inverter chip in your schematic ?
Old 9th October 2008, 12:35 PM   #53
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Of course you can use those class D amplifiers to drive the filaments, probably not at 50Khz, but slightly above 20Khz it should work fine.
I use to feel like the small child in The Emperor's New Clothes tale
Old 5th July 2009, 07:54 PM   #54
theAnonymous1's Avatar
I made new TPA3122D2 BTL boards, this time including a DRV134 to do single to balanced conversion. The DRV134 is running from the same single supply as the amp.
I like to try and use parts I already have if at all possible, so I went a little crazy with 1uF 100V X7R. There are 20 of them per board.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 5th July 2009, 08:40 PM   #55
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
You have outdone yourself one again, nice job!!
Also my question would be, why not use ...20d2, since it performs the same if not better and more power from it?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 5th July 2009, 09:17 PM   #56
Well, the only reason I messed with the 22D2 at all was because I have >100pcs of them and they are easy to play with since they are PDIP.
For surface mount package like the 20D2 I think the 06D1 is a better choice; like the board I made earlier in this thread. It doesn't require an external IC for BTL operation.
The above boards can swing ~11.5Vrms into 4R @ 20hz right before the over-current protection kicks in. That's around ~33W, which isn't too bad.
Old 6th July 2009, 06:07 AM   #57
luka's Avatar
lol that is way too much amps or channels in one amp
Why do you need them so much?
I FEEL SLOVENIA
Old 6th July 2009, 03:40 PM   #58
I don't need them at all. They end up sitting on a shelf after I build them.
Some people paint as a sort of therapy; I build small electronic devices I have no use for.
Old 6th July 2009, 03:48 PM   #59
luka's Avatar
HAHA they really much have been cheap
I FEEL SLOVENIA
Old 7th July 2009, 12:50 AM   #60
Cheaper than the 99USD Texas Instruments charges for an eval board.
I think I've just learned why a high PSRR closed loop system is better in some (all?) situations.
I've had a 41hz AMP32 running the front door speakers in my car for a few weeks while I make a DIY head unit. I replaced the AMP32 with these TPA boards and there was major alternator noise through the speakers. I knew it couldn't be a ground loop because there was only the two power wires hooked up and the source was a portable device; plus the AMP32 never had this problem.
I made a CLC filter of 6,800uF -> large toroidal inductor (?mH) -> 6,800uF and the noise completely went away.
Simple P-P 84 proto tubelab.com Tubes / Valves 64 21st July 2010 12:30 AM
New amp....intermediate proto. CBS240 Solid State 4 7th January 2009 06:57 AM
What do you think about my proto type? Whortless Chip Amps 1 23rd March 2007 07:51 PM
Copyright ©1999-2013 diyAudio
