Go Back   Home > Forums > Amplifiers > Class D
Old 22nd February 2011, 03:07 PM   #851
rubennn is offline rubennn  Denmark
Btw.. One more question (Sorry if I've overseen the question already asked): What are all those holes good for in the new design (on the peace of wood between the 2 drivers in each cabinet)?
Link me to the page if it's already been asked (sorry, but I just couldn't find it in this huge thread)
Old 22nd February 2011, 03:27 PM   #852
Saturnus's Avatar
Two-fold. Air circulation so that the port is loaded correctly, and to make sure the internal volume is correct. Believe it or not but the 0.3 litre smaller the internal volume would be per side without those cut-outs actually does make a difference for the correct tuning.
Old 23rd February 2011, 04:44 PM   #853
Darkwithin's Avatar
My boominator album
Roskilde since -06.
Old 23rd February 2011, 05:07 PM   #854
Saturnus's Avatar
Can you get a round-over bit for your router to smooth the woofer cut-out. Also remember the grill goes on the inside between the cabinet and the woofer, and you need to remove the rubber thing on the grill as well.
Old 23rd February 2011, 05:18 PM   #855
Darkwithin's Avatar
I dont relly understand, the speakers when i put the magnets together they are too small to fit in the box, and if I take the rubber thing off its gonna be even smaller.
I mean the measure on the inside is 27,6 and speakers with rubber on glued together is only 26,5 what do I do wrong?
I planned on putting the grill on the outside doesnt that work as well?
My boominator album
Roskilde since -06.
Old 23rd February 2011, 07:16 PM   #856
Saturnus's Avatar
They changed the design of the speakers some time last year. You need to mount a sealing gaskets on the inside like those you use to seal doors or windows to prevent draft.
I don't think it looks nearly as good. The grills will then stick out some 18mm on each side. Between the rubber gasket and the driver the grill is almost flush with the front.
Old 23rd February 2011, 07:46 PM   #857
Darkwithin's Avatar
I'll look into this and reconsidder putting the grills on the inside, you have a good point.
My boominator album
Roskilde since -06.
Old 24th February 2011, 05:47 AM   #858
@Darkwithin - Thats beautiful! Which piezo's are you using? And are you using a pair of resistors? In that case, how many Ohm?
Old 24th February 2011, 10:04 AM   #859
Darkwithin's Avatar
Thank you.
I'm using a replica bought from ljudia.se QLM-1005 69:- SEK.
I plan on using 1 150Ohm 5w resistor with every piezo. bought them from Conrad.se.
I think ill be able to get the HP-10W's to fit perfectly well have to see, more pictures coming tonight.
My boominator album
Roskilde since -06.
Old 24th February 2011, 06:41 PM   #860
Darkwithin's Avatar
My boominator album
Roskilde since -06.
Copyright ©1999-2013 diyAudio
