| Class D Switching Power Amplifiers and Power D/A conversion |
| Thread Tools | Search this Thread |
#1101 | |
*Maybe I should note that the port is 3x12cm but with 3cmØ rounding in both ends, so the resulting calculation is 3cmØ area plus 9x3cm, or 7,07cm2 + 27cm2 = 34cm2 That was fast. I didn't even order mine (and Wilcken's) yet. Last edited by Saturnus; 15th April 2011 at 09:01 AM. |
#1102 | ||
![]() Quote:
#1103 |
Yes I'm a bit surprised too, since they were listed as "more than 10 available" until yesterday. But maybe it's a good idea to order them anyway so you are first in line.
#1104 |
Exactly. Just blind luck I guess but if the cabinet size and the port size is identical to the original then the resulting response graph is pretty much identical as well. So no need to change anything.
#1105 |
Aah! I think I'm getting a hang of WinISD now.
Meanwhile I've been looking at some ports online and found a really cheap one 7,5 cm (cross area 44,2 cm2). I put this WinISD and it calculates 5,63 cm port length. There should be no problem in using this instead, right? It's still the same tuning 69,8 hz. I'll just have to cut the port exactly 5,63 cm ![]() I'm building half a boominator for another camp and they are on a tight budget, so this port is appealing. |
#1106 |
I made these cutting instructions for my local hardware store to minimize the risk of something going wrong due to a missunderstanding.
Maybe someone else will find it useful. In total there are 19 cuts, some stores in Sweden charge by the cut (instead of for time). This means that the cuts would be 190:- at some places (10:-/cut) and 380:- at others (20:-/cut). Some cash to be saved for us cost aware builders ; ) |
#1107 | |
Also a board is 1220x2440mm. I used to work as a CNC programmer in the woodworking industry btw. |
#1108 |
Updated the order of the cuts and removed the size of the board, Ive seen different sizes from different stores, 1200x2400, 1200x2500, 1220x2440. It really doesnt matter which size, the cuts will work on any of these sizes.
Suitable scale when printing on a A4 is 30%. Last edited by Nahaz; 15th April 2011 at 01:25 PM. |
#1109 |
I also got a reply from the ebay seller stating that the tweeters were sould out and it would take several weeks to get new ones. He asked if I wanted a refund or wanted to wait.
I replied that I could wait, but I never got an answer from him. My main concern is not receiving the tweeters in time to finish the boominator before this years Roskildefestival. |
#1110 |
Btw, I forgot to mention. While at the saw, if you can get the left over 900mm bit cut into a few pieces of 132mm length then you can use those for guides to mount the centerbrace. Width of these aren't really important, anything down to about 30mm will work just fine.
| Currently Active Users Viewing This Thread: 4 (2 members and 2 guests) | |
| barbfa, Arty |
| Page generated in 0.12275 seconds (70.62% PHP - 29.38% MySQL) with 11 queries |
