Old 16th April 2010, 03:05 PM   #1401
troystg is offline troystg  United States
troystg's Avatar
osscar-
That is actually pretty neat, certainly not safe, but neat.
It gives me some ideas for REALLY cheap builds for friends. I usually make and give away several chip amps but the cost of the enclosure is generally the limiting factor. This opens all sorts of possibilities.. And the recipients would probably think it's cool to "see" the parts. Of course I have to make it idiot proof. Even though they are making better idiots every year... :-)
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 16th April 2010, 03:10 PM   #1402
osscar is offline osscar  Latvia
osscar's Avatar
Yes - its built- as a design element I tried to create it safe-shrinking tubes everywhere + gourmets etc.
If time is money then I'm out of time
Old 16th April 2010, 03:22 PM   #1403
Post 1398.
What type of transformer is that?
The rounded corners seem quite unusual!
Old 16th April 2010, 03:28 PM   #1404
osscar's Avatar
тпп 287-220-50К Old soviet transformer with primary 220V and six secondaries -
2x2,63V 2x5V 2x10 V - actual readings 2x16VAC in series.
90VA total.
There is also version where whole transformer was immersed in green paint .
This transformer is very quit - no buzz or hum like from cheap toroid.
Old 21st April 2010, 03:47 PM   #1405
Hi to ALL!
It is my new project of the 20W/4 Ohm or 10W/8 Ohm Class "A" amplifier on integrated microcircuits with 41 pieces BUF634T in each channel, included in parallel.
The amplifier works some months, but cases while is not present. Now the case is made at factory under my drawings. I wait for the termination of works.
Sounding was pleasant to all who came to me and listened
Photo of the amplifier I apply.
Other files:
- Circuit of Amp
- Computer model of case
- Impulse signal 1 kHz
- Impulse signal 10 kHz
- Impulse signal 20 kHz
- Sin 5 Mhz
Old 22nd April 2010, 07:46 PM   #1406
Original idea. Should R108 not connect to the other side of R107?
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 23rd April 2010, 02:00 AM   #1407
okkyn is offline okkyn  Singapore
What an art of engineering Prophetmaster! You even manage to put resistors between heatsink's fins
Old 23rd April 2010, 05:53 AM   #1408
Thanks!
Can be and so, but I consider that this R-C should be from outside a loudspeaker.
Adcom GDV-870 (DVD-Audio), Nakamichi ZX-7(Tape), Y-1 from A. Klyachin http://www.klyachin.ru/images/PF.jpg (Speakers), Pioneer PL-1250 (Vinyl), Prophetmaster's RIAA preamp & Power Amplifiers
Old 23rd April 2010, 06:47 AM   #1409
Thanks for an appreciation.
Radiators are lifted over the circuit board on 5 mm and resistors are under cooling radiators
Old 27th April 2010, 10:27 PM   #1410
JFet Buffered Gain Clone. This is my first GC.
Copyright ©1999-2013 diyAudio
