Ok. Third Amp finished with same results: relays close but no sound->input problem.
What do I do wrong?
1. Is a regular cd player output is ok as input?
2. + is connected in the first pin second row. - is connected to the first pin first row (groud).
3. A jumper is inserted to shortcut the - and ground.
4. Output is connected to the wago connectors related to the same input (jp5 pins 1,2).
Any help?
What do I do wrong?
Any help?
peranders said:If you have the inputs shorted, the amp silent then? Do you get a hum of you touch the input?
Both, yes.
Upupa Epops said:How is DC voltage at outputs of both opamps ( pin 6 ) ?
correction: -11.5V.
I use 18Vac toroid.
The tp1,tp2 voltage is 23.9V.
Op amps are opa134pa (TI).
Upupa Epops said:At TP1,2 you must have +/- 12 V DC ! If not, something is wrong ! Are you sure, that voltage regulators are at correct position ? Read again setup instructions !
It's 24V between them.
tp1, tp2 and ground is 12V voltage.
Upupa Epops said:At outputs of opamps, you must have DC voltage near zero ( +/- a few milivolts ). Which is this value ?
-9.5mv
Upupa Epops said:So all is OK, problem is probably only in input connection... Which DC voltage are at TP 3 and 4 ?
0v (as stated in the manual).
- Chip Amps
- Pavel Dudek's (Upupa Epops) LM4780 amp
