Old 2nd December 2003, 03:31 PM   #21
Rick NL is offline Rick NL  Netherlands
Hi, the attachment did not seem to come through, here another try,
Rick
After all it's the music
Old 2nd December 2003, 04:00 PM   #22
Raka is offline Raka  Europe
Raka's Avatar
and what if I simply put a passive net in the amp input, of course buffering the general input? If I go second order, I won't get more than a Bessel, but I thinK I can live with that.
I've been thinking about the substractive in the Pass paper, trying to get passive also, but didn't get something tangible, any hint?
What is beyond the speaker?
Old 2nd December 2003, 05:41 PM   #23
won't this design ossilate?
if only it could be used for good, not evil...
Old 2nd December 2003, 05:54 PM   #24
Previously: Kuei Yang Wang
ThorstenL's Avatar
Konnichiwa,
Originally posted by Rick NL
One thing is important with this topology: the feedback resistors shall be low ohmic in comparison to the filter resistors.
As also clearly spelled out in the Application note.
Sayonara
Old 2nd December 2003, 09:01 PM   #25
Kuei Yang Wang,
Yes it is spelled that the impedance around the negative i/p is around 100 Ohms but it is not stated why and what is the consequence when you don't comply to this rule.
It is important as on this forum many contributions state that around 220k/10k or even 470k/15k are sonically best for the gainclone. Not in this topology!
Rick
Old 2nd December 2003, 09:18 PM   #26
Nappylady's Avatar
Send a message via ICQ to Nappylady Send a message via AIM to Nappylady Send a message via MSN to Nappylady Send a message via Yahoo to Nappylady
The LM3875 datasheet typical app note includes a feedback capacitor that "ensures unity gain" for DC signals... so there must be some caveat to the "if gain < 10 then oscillate" rule...
Old 3rd December 2003, 07:47 AM   #27
ThorstenL's Avatar
Konnichiwa,
Inverting topology, not non-inverting....
Sayonara
Old 8th December 2003, 09:31 AM   #28
Cradle22's Avatar
Hi!
Could someone please check out, if this setup would work (and not oscillate)?
Non-Inverting XO with a gain of 22, circuit like in AD's online calculator (link above)..., low pass Bessel 75 Hz (or Butterworth with different values)
C1 2.2 nF
C2 47 nF
R1 1050 K
R2 35.7 K
R3 2.21 K
R4 105 ohm
Non-Inverting XO with a gain of 22, circuit like in AD's online calculator (link above)..., high pass Bessel 75 Hz (or Butterworth with different values)
C1 2.2 nF
C2 2.2 nF
R1 3320 K
R2 243.0 K
R3 2.21 K
R4 105 ohm
I know that inverted design is more stable, but I don't know how to calculate (didn't find a tools for this) the values for inverted design...
Thanks,
Arndt
A Sacrifice For Freedom
Lowpass Necessary? CarlosT Multi-Way 3 18th December 2006 02:26 PM
cut off frequency of high pass vs lowpass lopan Multi-Way 3 1st February 2005 05:57 PM
Active lowpass filter + high rails Firebug24k Solid State 4 19th September 2004 07:47 PM
Lowpass or Bandpass???? soundNERD Chip Amps 7 1st June 2004 06:16 PM
how to make high/lowpass filter in series connection??? limking Multi-Way 22 24th July 2001 03:50 PM
Page generated in 0.11614 seconds (70.53% PHP - 29.47% MySQL) with 11 queries
