| Chip Amps Amplifiers based on integrated circuits |
#81 |
Since we are talking about wires, I'll sneak in an off topic post and not feel quite as guilty.
I have been looking at these for over a year but didn't want to get bitten by the snake oil monster .DIY Cat5 Speaker Cables The cost is low and the time necessary is mostly free, so I spent the better part of three days this week twisting wires and fingers. IMO, it was well worth the effort. The biggest impressions are an enhanced 3D effect and very clear , defined and controlled bass. Lots of slam when it is called for. I won't hijack the thread but will add a link to the post on the speaker thread when I get it there. Very nice with the FE amps. Could have used that solder pot on the ends !!
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 10th August 2012 at 07:09 PM. |
#82 |
Regarding litz leads of True Copper's: I used fine sandpaper to remove the insulation from the end of each individual litz wire after untwisting the ends. Took about 30 minutes per cap. Soldered just fine after that. Even with short leads, there was very little or no heat to the cap. I'd be very careful with these.
What proved to be a bigger concern for me was fitting the huge wires into PCB holes. I added a very short pigtail of fine gauge OCC solid copper to the lead. I hate adding another connection, but I had no choice, other than cutting a couple of the litz wires to make the lead smaller. I'm not sure what effect that would have. I guess these caps are built for crossover duty, not coupling. We may be pioneers! Bob, what value cap would you be getting in your potential group buy? Sounds like a great idea. Those speaker cables are insane. Do us all a favor and insulate the spade lugs before two accidentally touch and ruin your amp. Peace, Tom E Last edited by madisonears; 11th August 2012 at 02:42 AM. |
#83 |
Did anyone of you knows how well this litz wire can be cleaned and soldered using an aspirine tablet ?
Put the wire on top of an aspirin tablet and apply a well-tinned soldering iron. The insulation will come off after the aspirin melts and the wire will be nicely tinned. Be aware the resulted gas is very iritating. Last edited by atupi; 11th August 2012 at 08:26 AM. |
#84 |
Hi Tom,
After reading the wiki it appears the braid on the speaker cables can be thought of as an exaggerated application of the litz principal. That begs the question - Would there be an advantage in using litz between the FE and its chassis mounted in/out sockets? Don't know. Dario's video link shows a giant bulk reel. The cable photos show a temporary setup - done with caution. I have two versions of the Sunflower crossover. I'm using the original because the revised new one doesn't yet produce the correct timbre in the high spectrum where jazz trumpets are heard. I am in a dialog with Ken at Sonicraft in pursuit of a solution. His suggestion (guaranteed he says) is substituting some Jupiter Vintage Flat Stack caps - the total for my needs approaching $400. To my surprise, moving from a toroid to an R-core in my Mini 2496 DAC build produced the best trumpet sound I have heard. (BTW: the XO eventually will be mounted inside the woofer cabinet using a bi-amp capable plate. Humm - Maybe 4 EFs ??? )I'm reporting all of this here for a couple reasons. As with the True Coppers, there appears to be a valid case for blending between the world of high end crossover parts and those normally associated with amp building - ex. soongsc's question here. It will also be interesting to hear from RC builders who have the ability to compare toroids vs R-core transformers supplying the Fremen Edition. The caps in the quote request were 1.2 uF 630 VDC as you recommended originally. Do you recommend trying other values? I know many are hesitant to shell out that much money, and maybe you could report (or post a link) here informing FE builders of how you made this great discovery and what alternatives you tried. Dario suggested that a U.S. group buy for the solder pot might be in order. I'll be happy to organize that also if there is some interest. P.S. The ends of the speaker cable are temporary. You can see the barrel at the amp end is too small to fit over the bundle of wires and have to be replaced. Had to solder the bundle and file down to what would fit - kind of like your problem fitting the TC leads. I also ran out of high quality solder. When I get what I need the ends will be redone with insulation and the entire cable covered with nylon mesh. Additionally, on the other extreme, last weekend I tried some "Euro Style" single strand Radio Shack 30 ga magnet wire for cables with surprisingly good results from mids up. Really impressive stage and definition.
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 11th August 2012 at 11:18 AM. |
#85 | |
Reality first!
![]() Maybe it's not clear... what I've suggested it's not a solder pot for each partecipant but a single one to be shared among them.
Dario ClaveFremen "Bailando Salsa en el Sietch" |
#86 |
That's a possibility. Using the smallest box (click -> "more"on selection) is $5.35 to move it around. What are the dimensions?
Postage Price Calculator
Bob M. "Arrange Whatever Pieces Come Your Way." |
#87 |
A single solder pot paid for by the group buyers and the group receiver pre-tins all the cap leads before sending them out to the buyers.
Then decide who gets to keep the solder pot (DIYaudio). |
#88 | |
Reality first!
![]() Inviato dal mio LT22i con Tapatalk 2
#89 |
Hey Andrew, good to hear from you. Hope your vaca was enjoyable. We are expecting a travel log video post soon.
![]() Builders - pleas send a PM if you are interested - even if you don't plan to buy the True Copper caps at present. That way we can determine the need to pursue this path.
#90 |
Do you guys try to wash off the tacky flux after soldering? They say you don't have to, but there is more flux left than usual.
If you do remove the flux, do you wait until all components are soldered? My though is alcohol and a toothbrush, but I am very open to suggestions. Jac |
| Last My_Ref Fremen Edition RC boards for sale | ClaveFremen | Swap Meet | 3 | 4th December 2012 01:04 PM |
| My_Ref Fremen Edition - need help on PCB evaluation | ClaveFremen | Chip Amps | 444 | 29th October 2012 11:38 PM |
| Hx-Home Edition and Hx Mini Edition will be released December, 24th | destroyer X | Solid State | 54 | 3rd September 2012 03:44 PM |
| My_Ref Fremen Edition - Beta build/Fine tuning | ClaveFremen | Chip Amps | 1519 | 16th August 2012 04:05 PM |
| Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted | tiefbassuebertr | Multi-Way | 2 | 20th September 2010 11:20 AM |
