Old 18th June 2011, 08:01 PM   #31
hurtz is offline hurtz  Germany
Originally Posted by Juergen Knoop View Post
there is a short between pin 10&11 and pin 7 doesn't need to connected to ground via such a large track width, 0,5-1mm would be enough
Yep, but since pin 11 is not connected, it doesn't matter and I wanted to give the input line more room.
Wait isn't pin 7 the ground pin on the board? where at least the dissipated power flows through?
Originally Posted by infinia
Also since this a gain clone copy, ie minimal design
A) there is NO DC block on the inverting network. so it's possible to have significant DC offsets at the speaker.
B) there is NO RF filtering either on the input or output. The user can and should provide some provision for this in the final design. Same is true on the PS PCB.
And again I have no idea what this is about could you explain this a little bit further/point me in the direction where I can read about this?
Since I plan to use single sided PCBs with a dimension of 120x80 it would still be convenient to have a 40x30 board rather than 40x24 now.
mü-amp v3.1
Some minor changes, I moved some parts around to use caps with 8mm diameter, and nearly four times the capacity, 2.54mm pads are still present, so updated:
Code:
-Cs1,Cs3: Panasonic   220uF   35V   20%   5mm   Impedance:0.09Ohm   Ripple:730mA *2
cheers!
Old 19th June 2011, 12:30 AM   #32
Just for the fun of it I made an even tinier version, with smd components(the dark blue stuff). Enjoy
nü-amp:
Old 19th June 2011, 12:36 AM   #33
infinia is offline infinia  United States
infinia's Avatar
The NS schematic with some parts marked "optional" are not really, except for advanced users or risk takers. The major item that impacts your amp PCB is the DC blocking cap in series with Rg. almost everything you need is in the NS data sheet.
RF filtering on all inputs / outputs including AC entry, is generally good design practice and depends on the PCB final application circuit/s or parts, layout wiring, and chassis design.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 19th June 2011, 09:51 AM   #34
We could all make the chipamp smaller if we choose to omit essential components.
That choice comes at the expense of reduced reliability.
Old 19th June 2011, 06:26 PM   #35
AMP v4.0
New: RF-Filter to Input/Output
New Parts:
Code:
Cc: BCC   220pF   50-100V   5%   2.5mm   *2
Rb:  10k  0.25W     *1
R: 10R   2W
L: 1uH   7.5A   0.6mOhm   5mm
cheers!
Old 20th June 2011, 09:06 AM   #36
Try reducing Rb to 1k0 or 2k0
Old 20th June 2011, 11:04 AM   #37
Ah sorry typo..
Rb: 1k 0.25W *1
With updated, slightly more separated return of the speaker.
cheers!
Old 20th June 2011, 11:22 AM   #38
I cannot agree with your layout philosophy of mixing the Signal Ground with the everything else Ground.
I recommend that Signal Ground and what needs to be connected to it, be kept completely separate from the Power Ground and Zobel Ground and PIN7 Ground and Speaker Ground.
Old 20th June 2011, 11:31 AM   #39
just another
wintermute's Avatar
Agree 100% with Andrew on this point The data sheet is your friend.
LAYOUT, GROUND LOOPS AND STABILITY
The LM3886 is designed to be stable when operated at a
closed-loop gain of 10 or greater, but as with any other
high-current amplifier, the LM3886 can be made to oscillate
under certain conditions. These usually involve printed circuit
board layout or output/input coupling.
When designing a layout, it is important to return the load
ground, the output compensation ground, and the low level
(feedback and input) grounds to the circuit board common
ground point through separate paths.
Otherwise, large currents
flowing along a ground conductor will generate voltages
on the conductor which can effectively act as signals at
the input, resulting in high frequency oscillation or excessive
distortion.
It is advisable to keep the output compensation
components and the 0.1 μF supply decoupling capacitors as
close as possible to the LM3886 to reduce the effects of PCB
trace resistance and inductance. For the same reason, the
ground return paths should be as short as possible.
In general, with fast, high-current circuitry, all sorts of problems
can arise from improper grounding which again can be
avoided by returning all grounds separately to a common
point. Without isolating the ground signals and returning the
grounds to a common point, ground loops may occur.
You might note that this is a larger excerpt to what I posted before
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 20th June 2011, 12:46 PM   #40
Just to make sure we're on the same page here, the marked grounds are those that the datasheet speaks of right? the common ground point can now be either on the AMP itself or on the PSU as I understand it. (I assume with the cGND on the AMP it is better to have seperate grounds on the PSU)
And interpreting the datasheet, Those GNDs should be returned individually, except for (low-level) feedback and input?
Note to self: Get better in english >.<
lm3886 single sided pcb ryan750 Chip Amps 37 27th May 2013 04:15 AM
Lm3886 single sided my first try ampimp Chip Amps 0 14th October 2010 10:08 AM
Single sided non inverting LM3886 PCB tla-Audio Chip Amps 35 1st April 2009 07:16 AM
Single sided lm3886 board, opinions? Adam Eng Chip Amps 0 5th August 2005 03:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
