anybody tried a LM4780?
Old 11th August 2003, 05:17 AM   #1
travis is offline travis
Send a message via AIM to travis
Default anybody tried a LM4780?
its stereo 60 watts. 120 mono
http://www.national.com/pf/LM/LM4780.html
i want to try out the bridged mode.
think it could possibly sound good like a 3875?
i'm more sure its fine for PA uses which might be something i want to build.
this pdf is really informative.
what's the deal with 3 differenct cap values on the rails?
you guys hate built-in mute circuitry though.
i'm trying to think of a good way to set one up where its really easy to change components to try different stuff out.
donuts
Old 11th August 2003, 05:27 AM   #2
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
I was looking into the LM47xx line of chips, and am gonna throw something together to see how it sounds soon.
But it probably won't sound as good as the LM38XX line, they're listed as high-performance, and for a reason, the 47s seem to be more aimed towards ease of use and efficiency.
It's worth a try, one is a stereo p[art (only 11W though) that has a built in beedback resistor.
Old 11th August 2003, 04:31 PM   #3
Sawzall is offline Sawzall
Default Interesting voltage on rails
Interesting that is a 60watt amp but will take such large rail voltage +/- 42v, 92v max peak to peak... and given that it is two amps in one chip, it is like it is begging to have emmiter followers added on to a BTL. If it put out 75v (which it should) each, that is 150 volts p2p.
Old 11th August 2003, 05:03 PM   #4
On Hiatus
SY's Avatar
Why do you think this will sound less good than a 38xx? The specs here look pretty good.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 11th August 2003, 05:07 PM   #5
PaulHilgeman is offline PaulHilgeman
Account Disabled
The specs look very good, unless it just has a bad sound "character" to it, it shuld be a performer. I am very tempted to try one of these paralleled. Using two of these chips in a BPA alignment could be very rewarding. Two chips, about a total of 12 resistors, 4 capacitors, and you could have a very high powered amplifier.
-Paul Hilgeman
Old 11th August 2003, 05:18 PM   #6
On Hiatus
SY's Avatar
Do you know the availablilty of the chip and/or demo board? This is one I'd really like to try.
Old 11th August 2003, 05:40 PM   #7
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Just done a quick troll around the UK small order distributors, and non of them have that chip up yet, but it certainly looks interesting.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 11th August 2003, 05:48 PM   #8
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
This does look like what a lot of us have been waiting for.
I want it for a PA amp so quality doesn't have to be absolutely the best-just a lot better thean those pig PA amps out there..
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 12th August 2003, 12:07 AM   #9
SkinnyBoy is offline SkinnyBoy  Australia
Banned
Send a message via MSN to SkinnyBoy
Hmm... Interesting.. especially seeing I have a transformer that';; give +-45 volt rails with no load..
In Parallel mode with +-40 volt rails, it'll give 160watts into 4 ohms at 1% distortion... good for a sub..
Old 16th August 2003, 02:41 AM   #10
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
amybody tried this chip yet?? need a schematic for an inverted version...seems it will use less parts...easier to construct I guess...but the pdf does have some wuickie examples...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
anybody tried a LM4780?Hide this!Advertise here!
Lm4780 SS PCB pinkmouse Chip Amps 97 13th December 2012 11:50 PM
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 12:37 PM
LM4780 from who? jarre Chip Amps 6 10th August 2006 07:04 AM
lm4780 p/s j9184p Power Supplies 4 28th June 2006 04:18 PM
lm4780 odysseybmx414 Chip Amps 2 22nd February 2005 06:13 AM
Copyright ©1999-2017 diyAudio
