| Chip Amps Amplifiers based on integrated circuits |
Hi all,
I have built this kit successfully and have used an ALPS 50k log pot, however the music sounds "restrained" on playback. But, if I use the preamp section of my receiver (Yamaha RXV1900) and turn the pot all the way up on my LM3875's I get the sound I am wanting. My source is a Gigawork DAC. So, what is the best way to move forward? Will changing the ALPS out for something else be OK, or do I need a preamp? Is my ALPS at 50K to high? How do I calculate the correct value? If the preamp route is the way to go, can anyone point me in the direction of a suitable kit? Thanks, Dan |
#2 |
The 50K Dual Log Alps Blue with a 47K metal film shunt resistor should be perfect for your LM3875. I use that configuration to great effect in my Audiosector LM3875 premium kit.
#3 |
Dan -
If you post your question in the appropriate thread in the Audio Sector Vendor Forum you will likely get some advice from Peter D. himself. I think he recommends a pot in the 10-20k range. |
#4 |
Here is the schematic of my passive attenuator. It is a dual input/dual output. It also contains a single ended class A MOSFET headphone amplifier. I use a CDP direct into the pre as my primary source. I have a tuner as my second source, and although the output voltage is less than the CDP, it still sounds very good (imo).
I tried 20k and 100k before I settled on the 50k/47k shunt option. In my opinion, it gives the most natural presentation. |
#5 |
wire the volume control correctly and remove the added series resistors.
regards Andrew T. |
#6 | |
Zebra - so adding a 47K resistor on my inputs is all I would need to try? Will also put a post in the Audiosector forum Thanks, Dan |
#7 |
My comment was referring to Zebra's pic, the preceding post.
regards Andrew T. |
#8 | |
Regards, Chris. |
#9 |
#10 | |
I tried this setting on my own Audiosector LM3875 amp and found the sound to be a little bit clearer than with standard alps pot, particularly at low volumes. Now, there is a negative side : to work fine, pot and resistance must have about the same value, so even at full level this is a divider where you lose half of the sensitivity of the amplifier... |
| X-preamp volume control | MBK | Pass Labs | 45 | 3rd July 2008 09:14 PM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| Volume control for lm3875 amp | Arx | Chip Amps | 10 | 23rd September 2007 09:25 PM |
| Preamp volume control?? | Craig405 | Tubes / Valves | 7 | 10th September 2005 10:32 AM |
| Passive volume control options for the Behringer DCCX | RyanC | Digital Line Level | 10 | 10th June 2004 12:58 AM |
| Page generated in 0.09896 seconds (78.87% PHP - 21.13% MySQL) with 11 queries |
