| Chip Amps Amplifiers based on integrated circuits |
Hey All,
This is my first post here but I have spent quite a bit of time reading up on these forums and gain incredibly valuable information. I have decided on an amp that I want to build and will be building a stereo LM3886 amp from chipamp.com I order the chips and boards from chipamp.com and sourced parts from across the web. I feel that I have the opportunity to make a pretty awesome amp for myself but of course only time will tell. Before I begin I have a couple of questions for those of you out there that can answer. I am trying to build a nice amp without breaking the bank so no shortcuts but not overindulgences. It will be an integrated amp with an attenuator or pot and 3 way selector switch. I will likely be attaching a Sony 6 Disc CD player, iPod/laptop(1/8 to RCA) and a turntable with separate pre-amp. 1. Solder: I have read on here that the 37/63 mix solder is highly recommended but in what diameter is best for the mainly PCB soldering in this amp? 2. Internal Wires: Seems to be a big range here and I would like to keep my costs as low as possible. I have heard talk of Cat 5 cable. Seems like this would be nice as it is cheapish and colorful. Should I use different cable for different components? 3. Attenuator: What value would be best for this set up. I have read 10k from some 25k from others and 50k. The wiring of this will be similar to Peter Daniel's integrated amp (i.e. not a powered pre amp stage). 4. LEDs: I was hoping to add input source LEDs up as I have purchase a 4 pole switch. Can you recommend a wiring method for this? Thank you! I look forward to sharing my build with you as it progresses |
#2 | |||
The proper answer is have a selection of solder wire gauges and a selection of tips for the iron. Quote:
Anything carrying mains, needs mains rated (for insulation safety) cable. Keep signal leads short and used screened cable correctly grounded... grounding is where most DIY efforts fail. The amp should be silent... no hum etc. Quote:
Easy, you wire the spare "wiper" of the switch via a resistor to the positive rail of the amp (choose to give around 10milliamps for starters... depends on the LED's). You can discount the LED volt drop, so the resistor is Vsupply/0.010 in ohms. Each pole of the switch then goes to an LED and the LED cathodes are all tied together and returned to ground. If it's to bright increase the resistor. Many modern LED's are bright at under 1 milliamp so you will have to experiment to see what suits you.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
I agree with Mooly, except the LED detail.
I would try starting at 2mA for brightness. It is far easier to add resistor in parallel than try to snip and add a resistor in series. Just leave the resistor leads on the back side slightly long. These can be used to attach and detach an extra parallel resistor. The formula becomes LED resistor = [Vsupply - Vled] / 0.002 ohms eg Vsupply ~10V Vled ~1.9V Resistor value = [10-1.9] * 500 = 4050ohms, use a 3k9 or 4k3
regards Andrew T. |
#4 |
Hello,
Thank you both for your quick and thorough replies. These are hugely helpful and am I very excited for my project to begin. For clarification on the wires, is 5 amp cable what I am referring to as Cat 5 cable as shown here: Category 5 cable - Wikipedia, the free encyclopedia I really like the idea of this cable since there are many colors and its fairly cheap. I'll have to read up on the grounding more as there are a lot of topics on it and it seems to be of utmost importance. For the LED: Sounds like its fine to draw power from V+. Should I do this as a spice in the wire? Maybe this will become clear when I get all the components in front of me. Is the wiper you refer to just another one of the tabs? There are four per selection and I was thinking three would be in, out and ground. So would I be taking a wire off V+ running it to the spare pin, running a wire from that to a resistor to the LED for that input and then a wire from the LED to the ground. I drew up a real bad diagram in paint if you wanna take a look at what I am interpreting. ![]() This is the switch I am using CK1457 6.35X20.7MM 4PL 3 POS FLAT SHAFT Lorlin Rotary Switches Thanks again for your help! |
#5 |
5 amp wire for PSU etc... see picture. Cat 5 is multicore and way to thin for the currents involved.
Switch... use your meter on ohms to identify the connections, a 4 way switch will have A,B,C,D "wipers" as shown and a 3 way, AB and C only. Your link is to a four pole 3way switch is that what you want ? or do you want a 3 way 4 pole ? First will allow you 3 audio inputs, the second 4. so anyway A and 1 connect and B and 4 and so on.Move the switch round a stop and it's A and 2 and B and 5 and so on. The 3 way will only have A,B, and C the 4 way will add another "D"
#6 |
I think the 4 pole 3 way switch is what I want since I only need to switch 3 inputs. I was reading on
gainchooser about his passive preamp and it says "For the 3-step switch I chose a simple model from Lorlin (UK) with 4*3 steps. That means I'm able to switch both channels AND the ground signal and still have one range of contacts left for future use, for example to switch LED's that indicate which channel is active." Would my wiring diagram work for this? I'm no electrical engineer but it seems like the negative terminal of the LEDs need to connect back into the circut. Thanks again for your help and patience |
#7 |
The LED's are wired like this using any of the 4 ways available eg A and 1,2,3,4 or D and 9,10,11,12 etc.
Switching grounds is something I haven't done on any of my designs... if you do this then you need to be sure that a ground is always present as the switch rotates to avoid very and possibly damaging "noises"... such as you get not fully inserting a phono lead/interconnect. Edit... just reading your link on the preamp... I like the case post #31http://www.diyaudio.com/forums/headp...one-amp-2.html
------------------------------------------------------- A simulation free zone. Design it, build it, test it. Last edited by Mooly; 10th May 2010 at 06:30 PM. |
#8 |
Got it! Thanks for the reply I should be able to get the LEDs wired up though I suppose the LEDs are a pretty small piece to the amp building puzzle.
Thanks for the help I hope to show off my amp sooner than later but I'm going to take my time with it. |
#9 |
Okay, making great progress here!
I got the boards and most of the components and soldered it all together. I am still missing a couple things-the case is the big one at this point. I am left with a couple more questions that I hope you all in the DIY Audio community can help with. 1. The LED in the BrianGT(chipamp.com)'s power supply board. I ordered just the board and need to get this LED. I know its blue but what kind of specs (voltage) does it have or is that unimportant? 2. For the LEDs to indicate input source, I appreciate all of the help to my noobish self. I am wondering the best way to attach them to V+. Can I just strip off some wire and loop them around or are there connectors for this? I assume I should be taking it off of the V+ rail after the transformer but should I take it off after the power supply board? 3. One more quicky. I have and IEC plug, fuse holder and switch. Would the order be (from main in). IEC plug, fuse holder, switch, transformer or IEC Plug, Switch, fuse holder, transformer. The switch is 20A rated. Thanks! I'll try and get some pictures up of my progress thus far soon. |
#10 |
1. You can use any LED. You may have to adjust the resistor value, though.
2. You can just use any wire, but avoid loops. Keep it short and straight. It should be connected after rectification and smoothing, i. e. at or after the power supply board. The connection of the blue LED is a good indication, where to do that. 3. The fuse holder first, then the switch. That way you also have protection, if a wire comes off the switch.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
| Greetings and a couple of questions | Sasquatch | Tubes / Valves | 18 | 10th February 2007 08:49 PM |
| Couple of quick questions | Hastur | Pass Labs | 2 | 2nd June 2006 07:47 AM |
| a couple questions | slackerbob | Solid State | 1 | 12th August 2003 02:25 AM |
| Page generated in 0.13838 seconds (85.26% PHP - 14.74% MySQL) with 11 queries |
