Old 15th March 2010, 12:16 PM   #1
Default Designing a super low distortion headphone amp.
So - decided to build myself an insane headphone amp.
Im going to build it using the guidelines on this site for low distortion, low noise construction, no C-in, film caps etc.
So far, my choice of chip is an LM1875 power amp. I know its massively overkill for an headphone amp, but i do plan on winding down the gain, and putting in a attenuator using non wire wound resistors to reduce noise.
So, is LM1875 a good chip for headphone amps?
Old 15th March 2010, 12:40 PM   #2
wahab is offline wahab  Algeria
Will work, undoubtly, but will lag considerably compared
to a smple op amp + Class A biaised discrete devices.
A simple NE5532 + a pair of sanken darlingtons will blow it away..
Old 15th March 2010, 12:44 PM   #3
thank you for your input.
Im going to google for some circuit diagrams.
Old 15th March 2010, 12:54 PM   #4
Banned
John Conover: Direct Coupled Stereo Headphone Amplifier
You'll be hard pressed to better this.
w
Old 15th March 2010, 12:56 PM   #5
Portable 9V Headphone Amplifier by NE5532 | Circuit Project Electronic is something i just found.
Old 15th March 2010, 12:57 PM   #6
w
holy crap, i dont think im going to go this far, i only have a 60 dollar set of Phillips SBC-HP250 headphones!
Old 15th March 2010, 01:20 PM   #7
found something that look like this one..
high current discrete audio buffer
Old 15th March 2010, 01:24 PM   #8
wahab, i love that circuit, clean.
However, no way to adjust bias current, and diodes have variable forward drop due to temperature. Are you relying on the op-amp to minimize crossover distortion?
Old 15th March 2010, 01:36 PM   #9
To adjust the bias, a pot in serial with one of the diodes will
be enough., although it s useless as the strip of 6 diodes makes the
amp biased in class A.
The current is limited by the power devices emitter resistors.
You can also change these resistors to choose your bias.
It is very stable anyway.
also, you can use two darlingtons as power devices, this will make the
circuit even more simple, and that s what i made mysef.
Old 15th March 2010, 01:51 PM   #10
so its more of a class A amp.
I like it!
Thats why you warn to mount the transistors on heatsinks, power dissipation.
Low-distortion Super-pair Buffer simulation schematics linuxguru Solid State 29 12th November 2010 09:34 AM
Ultra low distortion amp eicen Analog Line Level 10 26th February 2008 01:02 AM
Q: headphone amp with variable distortion vladn Headphone Systems 3 17th February 2008 02:16 PM
amp with low volume and distortion vlljpior Solid State 10 7th June 2006 02:46 PM
Slone low distortion amp problem 5th element Solid State 4 30th January 2003 10:58 AM
Page generated in 0.09850 seconds (79.16% PHP - 20.84% MySQL) with 11 queries
