Compact Sized LME49810/11 +ThermalTrak Amp - Page 30 - diyAudio
Old 24th November 2012, 01:29 PM   #291
panson_hk's Avatar
don't worry for stability. no problem.
Old 24th November 2012, 03:05 PM   #292
Idefixes's Avatar
Send a message via ICQ to Idefixes
Ok , thanks, than i will build with NJL4281/4302 and 5171/1930.
Marc
website : http://audiyofield.wifeo.com/index.php
Old 25th November 2012, 03:00 AM   #293
panson_hk's Avatar
please post your result here. have fun!
Old 26th November 2012, 08:25 AM   #294
Idefixes's Avatar
Hi panson,
Parts are solderer on board only NJL are not. I have on hand heatsink that mesure 300x75mm with 40mm thick (30mmfins and 10mm base). Would one so heatsink per amp board sufficient?
Marc
Old 26th November 2012, 10:49 AM   #295
Eddie2 is offline Eddie2  Netherlands
If I am allowed to give an answer to that question, I would say that such a heatsink
is large enough. But, if it would still get hot, you better mount a fan in front of it.
No, NO PANIC !! It does not need to run ful speed !!
A very slow running fan makes a heatsink so much more effective, that a smaller
heatsink is large enough, (and cheeper) or keeps it much cooler.
You never hear that fan !
Kind regards,
Eddie
Old 26th November 2012, 07:18 PM   #296
Idefixes's Avatar
Here they are. NJL devices will be soldered when mounting on heatsink. I have to mount LME49810 and driver heatsink too.
Marc
Old 26th November 2012, 09:21 PM   #297
panson_hk's Avatar
Marc
Nice build! The heatsink should be big enough.
Old 1st December 2012, 12:50 AM   #298
Kind regards,
Eddie
Absolutely agree with Eddie.
Old 1st December 2012, 07:05 AM   #299
Thanks ! :-)
Old 4th December 2012, 02:36 AM   #300
panson_hk's Avatar
Default 2nd generation board
I want to make a 2nd generation of this amp board. A Baker clamp as shown in Fig. 17.2 of Bob's book is being considered for LME49811. A sketch is show below. Any comment?
On Semi ThermalTrak davidallancole Solid State 639 1st May 2013 02:29 AM
LME49810 plus ThermalTrak single-board layout panson_hk Chip Amps 1 28th September 2009 10:57 AM
LME49810 W/ Thermaltrak CFP Output BarryJF02 Chip Amps 6 13th September 2009 12:23 AM
OnSemi ThermalTrak Arius Solid State 8 26th August 2005 04:09 PM
In search for a compact sized motorized pot yairf Parts 1 19th October 2004 02:56 PM
Copyright 1999-2017 diyAudio
