Old 11th May 2009, 07:56 PM   #1
Default LME49810/STD03 parallel pairs
Dear,
Just a question.
The LME49810 has a (typ) output current capacity of 60mA. In almost all cases you need a driver transistor with a descent Beta to make a power amplifier. As exception here the STD03 darlingtons which have a hFE of at least 5000 and even more by higher currents.
Does this means I can theoretical parallel as many as STD03's as I want since output current seems endless?
0,060*5000= 300pkA. Let's say I want to stack 12 pairs of STD03's would this be possible?
With kind regards,
Bas
Old 12th May 2009, 10:30 AM   #2
enzoR is offline enzoR  Netherlands
yes but you need to add resistors so that the Ib current distributes equally over the parrallel transistors.
Old 12th May 2009, 04:18 PM   #3
Thank you enzoR.
I was thinking about a value between 47 and 150 Ohm.
With kind regards,
Bas
Old 12th May 2009, 05:35 PM   #4
jackinnj's Avatar
Each Darlington pair needs it's own 200 ohm potentiometer...and you will probably have to experiment with the resistor across the bias pins to set the current across the diodes at 2.5mA.
Old 12th May 2009, 08:38 PM   #5
Dear Jackinnj,
Thanks for responding. Yes that is the next concern. 12 bias pot's is not fun...
However I saw in Musical Fidelity and Arcam design that they just tied all diode strings together to one pot. I don't believe this gives the best sound solution since there will be always differences between hFE's
With kind regards,
Bas
Old 12th May 2009, 08:46 PM   #6
jackinnj's Avatar
Originally posted by Sebastiaan
Dear Jackinnj,
With kind regards,
Bas
Ask Janneman -- he used individual bias pots in his PAX amplifier -- (Elektor April 08) and Sanken recommends the same thing...I believe it is due to the possilibity that the betas of the Darlington's might not be the same.
Old 12th May 2009, 09:04 PM   #7
Dear jackinnj,
I am agree with you and Jan that this is the best way. Also Sanken's application sheet advice a pot per pair.
However, this is how Arcam does it.
With kind regards,
Bas
Old 8th June 2009, 11:10 AM   #8
Send a message via Yahoo to minhtriet
Dear All!
I want to buy an amplifier with LME489xx driver one or two pair SAP15s. What LME chip I will choose? LME49810 or 49811?
Thanks.
Old 8th June 2009, 03:00 PM   #9
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
I am currently working on a project with SAP15s and LME49811. I think 49811 is the best solution for SAPs. Because they already have a biasing systems and do not need Vbe multipliers. So if you consider 49810 and 49830 has bias pins then 49811 (or LM4702) is the best for SAPs. Another point is 49811 has Class A driving stages..
Best regards,
Ozgur
Old 28th June 2009, 07:40 PM   #10
klewis is offline klewis  United States
klewis's Avatar
Dxvideo,
I'm working on the same thing. Can you post your schematic? have you mocked it up yet?
Ken
WTB: Sanken SAP15N + SAP15P (or SAP16 - STD03) Vil Swap Meet 3 22nd July 2009 05:10 PM
my lme49810 AMP evangelion1999 Chip Amps 20 25th April 2008 03:51 PM
Page generated in 0.10673 seconds (76.10% PHP - 23.90% MySQL) with 11 queries
