| Chip Amps Amplifiers based on integrated circuits |
#31 |
#32 |
.But who put them there,I wasn,t dissapointed
regards max |
#33 |
it was so cheap, I just had to find out what was in there!
so it turned up, obviously I didn't bother plugging it in, straight out with the screwdriver. Well, what's inside is a bit of a shocker. It's like a really cheaply made headphones amp. The sticker on the bottom rates it at 2W per channel, and that's optimistic. The most shocking thing was the quality of the PCB, which is about 1/2 a millimeter thick, and screwed direct to the chassis, which makes it warp like nobody's business. Also, the volume knob is illuminated by an LED which is just floating around in there not attached to anything but PCB. This is now a distortion pedal, basically. I'm gonna make some samples by torturing the little ******, hook up the speaker cables to a jack which goes into the front of a good guitar amp (not mine, in a rehearsal studio), and put a marshall into the front of it, and record the sound of it dying a horrible death. £10 well spent, and I get a fun blue box to put a class D amp in. |
#34 |
Jives11
mental led flashes red green & blue,chip underboard pastes to case base regards max |
#35 |
TDA8210 ~ ~ ~ in the 80s to the mid-1990s cassette tape recorder to see now that no one would like to use the~
#36 |
If it wasn't funny enough, with the help of SMD, 4-layer PCB and plannar magnetics, a 2x180W rms amplifier fed from 12V with SMPS could be really fitted into these tiny enclosures...
I squeezed 2x150W @ 4 ohms class D with 12V SMPS into 17cm x 10cm x 5cm Cool and small 2x150W class D full-range car amplifier With LCD display, bass, trebble, volume, input gain, power up defaults... But Chinese are certainly not up to the job ![]() ![]() ![]() It could be a nice challenge to actually fit a 2x180W amplifier into that case...
I use to feel like the small child in The Emperor's New Clothes tale
#37 |
Yes.the one i got sounds wonderfull,clarity,stereo,dynamics,it works.
regards max albin |
| Ebay 15W class-a zero feedback modules? | sharpi31 | Solid State | 4 | 24th July 2009 11:24 AM |
| ready-to-use Ebay Chinese DACs | jarthel | Digital Line Level | 0 | 6th June 2009 12:40 AM |
| cheap eBay chip amp modules! | Juicie | Chip Amps | 7 | 25th October 2008 03:48 AM |
| Cheap and Chinese KT88 SE amp | andrew_whitham | Tubes / Valves | 46 | 19th May 2007 11:05 AM |
| WTT Amp6 Int. Amp for cheap chinese tube Int. Amp | mrdon | Swap Meet | 2 | 28th July 2006 11:03 AM |
| Page generated in 0.11356 seconds (64.31% PHP - 35.69% MySQL) with 11 queries |
