| Chip Amps Amplifiers based on integrated circuits |
#2 |
i think it's great idea..... but still waiting the answer from others
#3 |
Since that's a dual secondaries transformer, why don't you use dual rectifiers? See photo.
Hey, the big caps can be nice, but you might want to add a pair of 2200uF or 3300uF. Those charge/discharge fast. Refer to CarlosFM 2004 design. Oh yes, here's a dual rectifier photo. |
#4 |
Depends what you mean by work. It will give -/+25 volts DC. Is that what you want ? You need diodes with a high surge current rating for big caps like those and with at least a 100 volt P.I.V. rating. Regards Karl |
#5 |
Make sure the phasing of the transformers is correct otherwise it will just be a paralleled half wave rectifier. ie. the ripple frequency will be the mains frequency rather than double the mains frequency.
You have taken one step towards improving the basic PS design. The 10nF across the diodes cuts out most of the switching noise. The next step is adding some film caps across the main reservoir caps, anything from 0.1uF to 10uF is typical. There are many more steps beyond...
Glenn. |
#6 |
use a light bulb for the first power up.
and again every time you modify the project. |
#7 |
Yes, my target was to get +/- 25volts powering up my split supply amp. But is there any difference between single supply and split supply amp?
I build a chip amp TDA2005 with a single supply, would it make any difference with a split supply design? ok, now this bridge diode, i believe any 5amp rating bridge should suffice, would it? as for the filter caps, usually 2200uF 50v would be ok. |
#8 |
as suggested, i've revised the schematics:
#9 |
Diode ratings?
use dual 35A installed inside a bridge rectifier. i.e. two each way. |
#10 |
+-25V and 2200uF smoothing does not sound right for an 8ohm speaker.
The peak current into a resistive load is [Vpsu-Vloss]/Rload~=[25-4]/8=2.6amps peak. Into a reactive speaker load the peak current can be two to three times this value i.e. approaching 7Apk. The ripple on 2200uF will be enormous. |
| A question about powersupply fuses? | roger-k | Solid State | 7 | 19th November 2006 01:30 PM |
| box design question | hunter | Multi-Way | 3 | 20th July 2002 02:38 PM |
| Aleph powersupply design question | kasra | Pass Labs | 12 | 11th June 2002 05:47 AM |
| basic question : reduce amps supplied by powersupply | fezz | Solid State | 0 | 26th March 2002 08:58 PM |
| Aleph 2 LC powersupply ...question.. | hifi | Pass Labs | 16 | 3rd February 2002 05:27 PM |
