LM1875 PCB, Which To Use
Old 3rd April 2008, 07:30 AM   #11
Nordic is offline Nordic  South Africa
Nordic's Avatar
Not a problem, need to take a drive to the PCB factory quickly, but when I get back I will prepare and post it for you.
Old 3rd April 2008, 07:57 AM   #12
Paswa is offline Paswa  India
Paswa's Avatar
thanks nordic, thank you very much , please try to do it a little quickly,,I'm just can't wait anymore to build the 1875 chipamp and to enjoy my favourite musics. I know you'll do for me.
And, what about my PCB? is there any mistake? that you found?
Old 3rd April 2008, 08:45 AM   #13
Paswa's Avatar
Is the circuit of the PCB is 5 all right ? http://www.diyaudio.com/forums/attac...amp=1201427555
Old 3rd April 2008, 09:09 AM   #14
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Is it possible to move the resistors pictured, just a bit farther away from the power caps?
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 3rd April 2008, 09:59 AM   #15
Greg Erskine is offline Greg Erskine  Australia
Greg Erskine's Avatar
Yes.
Greg Erskine
Old 3rd April 2008, 01:17 PM   #16
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Default Re: LM1875 PCB, Which To Use
Originally posted by Paswa
There are many PCBs. But what to use?
What are your soldering skills like? Do you plan on making your own boards or having a board house make them? The answers to those questions will narrow down your choices...
I made a PCB of 1875 toooo...see it
So why not just use your own design and see how it works? That will probably sound better to your ears than any other design
Brian
Old 3rd April 2008, 01:48 PM   #17
Nordic's Avatar
Absolutely Brian, I think your SMD boards are realy cute
What do you guys think about this layout then?
W=60.6225mm x H=51.744mm (2.4"x2.1")
I am tempted to add the PSU to the boards, it makes life so much easier, less wires, less drilling etc.. and a cleaner look when installed, only requires a transformer ad the 2 boards in the case.
Old 3rd April 2008, 06:47 PM   #18
What would this one:
look like without the fuses?
I like it best because it has significant room between power and signal components, and because it can connect a wide variety of input filter cap sizes.
See, on the picture, if a poly input cap is wanted, then the input terminal can be omitted. That option makes room a variety of sizes, so it would be nice to have that option.
Speaking of SMD, howabout make the feedback resistor SMD? The back two pins of LM1875 are extra long, and I think that an SMD resistor just fits there. My only problem with going entirely SMD is (|00...0>^6 + |11...1>^6)*2, which will have stolen some of them.
Old 4th April 2008, 08:37 AM   #19
Paswa's Avatar
I'll request nordic to share the eagle .brd file of the PCB with me, if possible..
And this is the PCB I designed without fuses,, is tyhere any error??
Old 4th April 2008, 10:32 AM   #20
Perhaps I would do this instead.
Center pin of LM1875 is -v
And, I'd move that 1m slightly farther from the power caps.
Terminal blocks can have the wires come loose, so I'd just omit it.
EDIT: Oops, however, I wouldn't increase the distance on the NFB resistor's leads like that picture. Sorry about that.
EDIT2: Um, those cap values.
Okay, the 22uF at NFB would be a 100v model, and then the 2.2uF at Input, should, instead, be 1uF polypropylene, like a Wima 100v MKP, which is rectangular.
IF, however, the input filter cap is supposed to be electrolytic, it would be 4.7uF (or 3.3) and the NFB cap would be 47uF.
LM1875 PCB, Which To UseHide this!Advertise here!
LM1875...how low can you go? Gcollier Chip Amps 7 6th May 2010 03:43 AM
How hot does an LM1875 get? Dominique Chip Amps 15 23rd January 2007 02:13 AM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 03:28 AM
Lm1875 soundNERD Chip Amps 14 12th October 2003 02:26 AM
