Hifonics BXI-6000D
if i short them, there is no more dc on the inductors. Yes i have a 10k resistor.
Found the resistors. Pin 1 is going to a 10k, from there to a 3,4k and from this to q2 base.
If i measure directly from pin 1 to Q2 Base i got 10k. Other side the same.
Leave the 2-3 bridges.
Solder the 10k resistor to the points indicated by the arrows below. One end to any green. The other end to any yellow.
Driving a signal into the amp, do you see the same drive frequency square wave at pin 1 of the two 21844s?
