I removed and replaced all 50n06 with 3205,s 47 gate resistors that where out of tolerence. I have one ps fet that keeps showing a strange short? I cant fiqure it out. Are my regulators shorted? Mur2020,s all the outputs test ok no shorts. Driver board is removed module 2
Indeed some 3205 are no good. So i replaced the banls with tested ones to insure they are simular and working now all are reading the 10.1ohm 1-3. So it powered up. Quick question. I need a completly excellent method for discharging caps, i used a resistor and think they are discharged only to get a pow!! Somewhere and it hurts my ears!! Especially on large amps. I dont care the cost i need a cuurcuit design or a safe method
Driver board I replaced all the transistors on this board. With the correct transistors I believe. And the 494. I only didn't change the. Q50, q49, q48, and q23 at the top of the board but the drivers I changed. Can I use different one a06, a56 if I use the 3205's? There is m6 and L6 in there now
- General Interest
- Car Audio
- Shrkamp 2500.1d help
