rock fosgate 250 a2 help.
ok after re-soldering the right side has sound.
the sound is not clean, at vary low volume when i switch the LP,HP cross over,
the speaker will go thud thud thud. more so in hp then in low pass?
the sound from the speaker,sounds like a blown speaker.
it is the same on both channels.
what does each side share that would effect the sound?
