I need some help finding a replacement for ktc1027.
KTC1027 datasheet pdf datenblatt - KEC(Korea Electronics) - EPITAXIAL PLANAR NPN TRANSISTOR (HIGH VOLTAGE) ::: ALLDATASHEET :::
And kta1023
KTA1023 datasheet pdf datenblatt - KEC(Korea Electronics) - EPITAXIAL PLANAR PNP TRANSISTOR (HIGH VOLTAGE) ::: ALLDATASHEET :::
These are used to drive the P.S gates
And kta1023
Well I've had this one put to the side waiting for the owner to pick up. I was testing it periodically and everything was fine. Today while hooking it up in the guys car it was on for a few seconds then smoke. I was embarrassed and almost blew my top.
One of the transformers has a short at the very last winding. I can see it spark. I guess I got lucky since is a easy fix. It did take out the transistors again though.
What should I use to coat this with?
- General Interest
- Car Audio
- audiobahn a18001dt
