audiobahn a18001dt
I had this hiding in a different folder.
Transformers seem ok. No dead shorts .989 mohm. One set of output center legs are 70v and the other sets outer legs read -69.8.
Even though the gate resistors read ok ( lowest reading 99.0 ohms) they are a little discoloured. Will this be a problem down the road?
Well I've had this one put to the side waiting for the owner to pick up. I was testing it periodically and everything was fine. Today while hooking it up in the guys car it was on for a few seconds then smoke. I was embarrassed and almost blew my top.
One of the transformers has a short at the very last winding. I can see it spark. I guess I got lucky since is a easy fix. It did take out the transistors again though.
What should I use to coat this with?
