The amp turned on but was pulling for 13v to 9 in a pulsing manner. The blue l.e.d 8002 ( same side as the red fault l.e.d) was also going on and off with the pulse. I turned it off and left it. When I returned tocheck the FETs, with just b+ and ground, q9902 and q9904 started to smoke. After I removed just the two FETs the amp was able to turn on as it did before when none were in (2 blue l.e.ds light up, one goes out and the red turns on)
This is my first attempted at a repair and I'm a little discouraged.
You were correct.
Ic9802
Pin 1: .002
Pin 2: .019
Pin 3: .004
Pin 4: .019
Pin 5: .123
Pin 6: 9.06
Pin 7: .123
Pin 8: .002
Ic9701
Pin 1: .004
Pin 2: 4.438
Pin 3: .102
Pin 4: 3.647
Pin 5: 1.688
Pin 6: 3.459
Pin 7: .004
Pin 8: 9.06
Pin 9: .019
Pin 10: .019
Pin 11: 9.06
Pin 12: 9.06
Pin 13: 5.051
Pin 14: 5.051
Pin 15: 5.051
Pin 16: .004
Ic9802
Pin 1: .002
Pin 2: .019
Pin 3: .004
Pin 4: .019
Pin 5: .123
Pin 6: 9.06
Pin 7: .123
Pin 8: .002
Ic9701
Pin 1: .004
Pin 2: 4.438
Pin 3: .102
Pin 4: 3.647
Pin 5: 1.688
Pin 6: 3.459
Pin 7: .004
Pin 8: 9.06
Pin 9: .019
Pin 10: .019
Pin 11: 9.06
Pin 12: 9.06
Pin 13: 5.051
Pin 14: 5.051
Pin 15: 5.051
Pin 16: .004
I'm looking at a function generator kit http://item.mobileweb.ebay.com/viewitem?itemId=300663054044&index=4&nav=SEARCH&nid=51509321741
It's puts out up to 1mhz. Is this ok or can I do better for a few dollars more?
Yes, there was 1 that measured shorted between the gate and drain and 4 that measured below .3v between the drain and source on diode test. The legs (gate and source on outputs FETs) are still desoldered from the board as i mentioned before. When its first powered on both blue l.e.ds light up then 1 turns off and a red l.e.d turns on.
Pin 1 of ic 9701 has a trace from the secondary of the transformer. Could this be why is reading the fault since the power supply fets arent in?
- General Interest
- Car Audio
- alpine pdx 4
