It's extremely unlikely that you'd have the same failure for all ICs if none of the output transistors failed. Did you reinstall the output transistors?
I justed tested with with 6.5" 100watt rms speaker and all channels play. They only thing I noticed is if the speaker is connected to the output and u touch the ground of the rca on the amp the speaker will buzz.
