Rockford Fosgate T30001BD
The rail voltage for these amps isn't like other amps. The output of the power supply is floating so, under normal operation, the red wire will swing from 0v to full rail voltage. The blue does the same. If you reconnect the wires, what voltage do you read on those two wires?
Check it with the black probe on ground as well as measuring directly across the red and blue wires.
