Go Back   Home > Forums > General Interest > Car Audio
Old 21st February 2010, 01:39 PM   #1
Default SinusLive SL-A1500 help needed.
Hey all.
I have a SinusLive SL-A1500 car amplifier
Error: The amplifier won´t start up.
Have any of you experience with repairing this amplifier before?
Best regards
Kim
Old 21st February 2010, 05:39 PM   #2
Is the amp completely dead or going into protect? If it's completely dead, post the DC voltages on the driver IC (TL494?).
IC#
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Old 24th February 2010, 07:27 PM   #3
Default SinusLive
Hello
Thank you for your time
The amplifier draws a lot off current and the red led protected lights
Do you have any idea where to measure in the amplifier?
Best regards
Kim
Old 24th February 2010, 07:32 PM   #4
Did you check all of the output transistors to determine if any had failed?
Old 27th February 2010, 01:25 PM   #5
Default Sinuslive repair
Hello
Now I have measured a bit in the amplifier again.
Transistor Q8 has a short circuit.
How many transistors in the ampifier do you recommend to be replaced?
All transistors Q1,2,3,4 and Q5,6,7,8?
Thanks for all for now
Best regards
Old 27th February 2010, 07:00 PM   #6
Yes, you need to replace all 8 of the outputs. Since you only found one shorted, reinstall the others, clamp all of the transistors down (you'll have to place the blown one under the clamp so you can clamp the adjacent output down tightly) and power up the amp. Does it power up and produce audio (at low power output)?
Use a 15 amp fuse in the B+ line to protect the amplifier in case there is another problem.
Old 11th March 2010, 11:47 AM   #7
Hello Perry
I have now replaced all the output transistors with 8 new. (IRF640)
The amp is still in protected mode.
I can measure 53V across the output transistors
Please help again
Kim
Old 11th March 2010, 05:29 PM   #8
Does the amp produce any DC voltage across the speaker terminals as it powers up (or after it's power up for a few seconds)?
Old 11th March 2010, 08:06 PM   #9
Yes there is about 10V DC at the output, "constant"
What to look for then?
Old 12th March 2010, 03:46 PM   #10
Hello again
The output varies between 0 and -10V
Have measured -46V at D17 katode here is suppose to be -12V
The katode voltage off D16 varies between +32 and -12V
Help me here?
Advice needed Technics Sl-15 cover removal musicmantech Analogue Source 2 31st July 2009 03:05 PM
technics SL-PS900 pics inside needed mat_one Digital Source 0 5th August 2007 08:39 PM
Technics SL-5 pinkmouse Analogue Source 22 5th July 2006 10:59 AM
technics sl-1600 kazoo Analogue Source 2 11th August 2005 01:10 PM
So/Sl ratio? Tomac Multi-Way 3 14th January 2004 11:48 PM
Page generated in 0.11010 seconds (80.78% PHP - 19.22% MySQL) with 11 queries
