What would you chose?
I'm planning to have my noble pot in the Audio Sector integrated changed to a 24 ladder stepped resistor control. Specifically a Scott Endler stereo attenuator. I've been told the 4k ohm might be the one to go with. The other choice is a 20k ohm unit. Which one do you guys suggest? My input impedance will be between 15 and 30 ohms...thanks to the buffer.
Thanks for any advice.
The pot used in an Integrated amp is 25k.
If Scott claims that 4k sounded the best, you may try that value, especially when buffer has very low output impedance. Otherwise, 10k or even 20k would be probably more suitable.
You can read about my experiments with passive volume controls here: http://www.diyaudio.com/forums/showthread.php?s=&threadid=73538&highlight=
The most recent one is getting closer to completion. Control interface was developed by Veteran:
Banned
Joined 2002
Banned
Joined 2002
Peter Daniel said:Yes, that buffer should work well with all amps, as the output impedance is 6ohm only.
The buffer should be installed on source output though.
Could i use it between source cd player and Amplifier ? I want to use it as a buffer with a nice pot. ie a small simple volume pot. I'm using one now as a passive pot but want to see what a buffer sounds like with out causing to much distortion.
Jase
Is there a way to get a balanced buffer in any way ? Would there be difference ?
Would i use it before the volume pot or after ( sorry just added that question )
Banned
Joined 2002
Peter Daniel said:I had very good results with buffer installed directly at DAC output and the switching attenuator directly at amp's input (one IC only)
Do i need to buy 2 of these or one ? Ie 1 Board will do both channels..?
All i need to add would be a transformer ?
Jase
Banned
Joined 2002
Peter Daniel said:A kit includes two boards, so one set is good for stereo, two sets neded for balanced setup.
All you need is transformer indeed (plus input/output connectors)
Interesting I could do balanced. .. Hum. Now im really interested. I wonder how it could compare to the Bosoz Pre-Amp that i currently have that buzzes and fuzzes.
The link has been posted here: http://www.diyaudio.com/forums/showthread.php?postid=887183#post887183
Peter,
one more question about the integrated. I would like to turn one of the inputs into a direct connection bypassing the volume control. Is this ok and if so what is the best way to do this?
I figure since I only use one input any way. Why not have a direct input where I can try TVCs down the road with no secondary volume control in the way. Basically turn my integrated into an amp only.
I would have someone more skilled than myself to do the work for me.
TIA
TIA
My friend that uses the SB3, AS DAC, Patek and Django just emailed me his impressions of adding the buffer and the DIP to his setup. He also uses Zu Druid speakers.
"after installing the buffer the AS DAC setup took a huge leap forward in performance.everything opened up , got better defined .top end now very nice and extended.more presence in the musical presentation , more emotionally involving.
adding the DIP adds another nice quality . it definetly cleans up the signal .the effect is not as dramatic as with the buffer but there is definetly a few veils that are lifted with it .
very very cool."
This is good!! Glad someone else hears what I hear when adding these components to the chain. The DIP may or may not be a dramatic difference depending on how bad the source was from the start.
Good listening!
very very cool."
Good listening!
GHM said:I would like to turn one of the inputs into a direct connection bypassing the volume control. Is this ok and if so what is the best way to do this?
I've actually built an amp like that. One set of RCAs (close to center) were not connected to input selector switch, but directly to the PCB input. The other two RCAs went throug selector switch to the pot and also to the amp's input on the PCB.
There was an additional toggle switch at the rear. That switch disconnected the pot (since the pot is parallel with amp's input) from circuit ground.
With such setup, you could either use the amp as an integrated with two inputs or as power amp only with pot completely disconnected from the circuit.
Hi Peter,
I finished assembling my LM3785 premium kit today (dual mono in power amp configuration, with 2 rectifing bridges and 2 toroids 300VA connected to a single IEC socket) but I'm having some problems getting it to work properly. I'm using my computer has source (when i connect the amp to my Marantz A/V reciever I hear only some kind of buzz sound) with some Kef loudspeakers but the sound I'm getting is very low and muddy. I think that all conections and solder joints are OK and I have all the grounds connected in one point.
Any help is appreciated, maybe some pics or tutorial would help newbies like me.
Thanks,
Paulo
Thanks,
Paulo
- More Vendors...
- Audio Sector
- AudioSector-chip amp kits, dacs, chassis
