Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 11th December 2005, 09:51 PM   #521
rjkdivin's Avatar
Default Chip Amp Configurations
Peter,
Could you explain, in relatively simple terms, the difference between Parallel and Bridged configurations for amp inputs and outputs.
Also, I understand the difference between Dual Mono and Stereo as being primarily the use of independent power supplies in Dual Mono....is there any other difference?
I thought I understood all of the different concepts, but now I find myself confused regarding Bridged and Parallel. I have read the application notes for the LM3875 amps, and the posts regarding the different set-up possibilities for the LM 4780, but I think I need an overall concept of Bridged vs. Parallel to put the pieces together.
I have your kits for both the LM3875 (two) and LM4780 (three), and was planning to use the LM4780 for a 5 Ch application, but I am trying to figure out if there is a way to configure more power out of the front 2 channels without going to balanced inputs (and I don't mind adding more kits if necessary).
Sorry for the elemental questions!
Thanks,
Robert
Old 12th December 2005, 12:08 AM   #522
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
The difference between dual mono and stereo is the number of rectifier boards used in powering the amp. In stereo, both channels are powered from the same board, in dual mono each channel has its own separate board.
While in stereo setups with a single transformer you could still use two separate boards, on more than one occasion I had reports of humming supply so I always recommend using a single rectifier board.
That's also what I'm doing in all my stereo amps and in the picture below I'm showing trouble free way to connect power grounds: output grounds of both channels (OG) are connected with a piece of thick copper wire. Central point on that wire is power star ground and all 4 ground wires from rectifiers board (PG+, PG+ and PG-, PG-) are connected here. Output grounds are taken directly from the board, signal ground connects to the point on the board marked as SG.
Those boards were designed with dual mono operation in mind and as such they work well without any mods.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 12th December 2005, 12:16 AM   #523
Here's the same idea in a Patek amp. Boards are positioned vertically now, and I created special grooves to slide in the copper wire connecting both channel grounds. Black wires from PS ( PG+ and PG-) connect to that point and grounds to speakers are also taken from here. Amp's chassis is connected through 10R resistor.
www.audiosector.com
Old 12th December 2005, 12:39 AM   #524
Parallel and bridged configurations are used to get more power from the chips. Paralleling is easier to accomplish as you simply connect inputs and outputs of both chips together, creating more current capability.. This will not really give more power into 8 ohms. Usually a single chip gives similar power into 8 ohms and into 4 ohms (at a given voltage supply) as it cannot produce more current. With paralleling, more current can be produced and the power into 4 ohms usually doubles.
A bridged configuration could be compared to using two chips in series. The balanced signal consists of two signals in opposite phases. One amp amplifies one signal, the other amp takes care of the opposite phase signal. The output is taken from between the two chips without referencing to ground. Such configuration creates higher output voltage levels, however does not have increased current capability, that's why it's not recommended to use loads below 8ohms and use moderate voltage supply levels.
The parallel configuration has no limitations with regards to source as it is still single ended. In bridged setup, a balanced signal needs to be supplied to the amp, so this requires a preamp, or source, with balanced output (those use XLR connectors, not RCAs)
You may have another look at this schematic, as it shows both ways of connecting two chips: http://www.audiosector.com/lm4780%20amp.pdf
www.audiosector.com
Old 12th December 2005, 02:28 AM   #525
rjkdivin's Avatar
Default Bridged and Parallel
A bridged configuration could be compared to using two chips in series. The balanced signal consists of two signals in opposite phases. One amp amplifies one signal, the other amp takes care of the opposite phase signal. The output is taken from between the two chips without referencing to ground. Such configuration creates higher output voltage levels. The parallel configuration has no limitations with regards to source as it is still single ended. In bridged setup, a balanced signal needs to be supplied to the amp.
Thanks Peter,
Thats exactly the kind of basic explanation I was looking for to go with the schematics.
Robert
Old 13th December 2005, 06:49 AM   #526
That amp was actually a custom order, I'm not sure if I offer 5 channel version as a product.
You should.. I think that looks even sweeter than the usual patek. Plus, then you can reach all the hometheater people.
Old 13th December 2005, 07:16 AM   #527
karma is offline karma  Canada
karma's Avatar
Default all digital amplifier
peter i had a chance this week to test a all digital amplifier.
and was suprized how clear it was and a very small footprint
for the watts it was pumping out.
have you had a chance to try one? what are your comments on this amplifier?
is this somthing u may build in the future?
http://sharp-world.com/products/1-bit/archives.html
http://www.electronicproducts.com/Sh...febti1.feb2003
Old 14th December 2005, 05:38 PM   #528
opt-e is offline opt-e  Canada
I'm a bit confused with your stereo amp setup. You say you're using a single rectifier board, but you have four ground wires from the rectifier? Shouldn't there be only two?
Also, it doesn't look like you have anything connected to PG+/PG- on the amplifier board. If grounds from the rectifier board are connected to the star ground then I assume connecting them to the grounds on the amplifier board is not necessary. Please correct me if I am wrong.
Old 14th December 2005, 06:21 PM   #529
The four ground wires consist of dual PG+ and PG- connections (in parallel, to increase current capacity).
There are no wires connected to pads marked PG+ and PG- on amp board, but the copper wire (connecting both channels) connects to OG pads (which is the same ground as PG+ and PG-). The central point on that wire is a star ground, and that star ground is connected to the output ground (OG) on amp's board.
www.audiosector.com
Old 14th December 2005, 06:28 PM   #530
Default Re: all digital amplifier
I'm not familiar with this particular amplifier, but I was listening both to Hypex modules ( have actualy 3 of them ) and NuForce 9 and without mods they are not in a same league as properly implemented GC. Still, I didn't have a time to perform the mods
BTW, the Patek chassis, both stereo and 5 channels, can also acommodate Hypex modules, same for integrated amp chassis.
www.audiosector.com
Copyright ©1999-2013 diyAudio
