Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 20th May 2011, 09:43 PM   #2801
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
AudioSector-chip amp kits, dacs, chassis Send a message via AIM to Peter Daniel
The advantage of dual mono configuration has been explained here: Commercial Gainclone kit- building instructions
How much difference it actually makes will depend on build quality, parts chosen and your complete setup.
You would only need a second transformer for dual mono configuration.
To order kits contact me through forum mail.
Old 23rd May 2011, 03:20 PM   #2802
deepblue2010 is offline deepblue2010  Luxembourg
Thumbs up DAC worked. Again, the system makes me hi-fi feelings
Peter,
I just powered SPDIF DAC about an hour ago.
Source is a Phillips DVD729K, using its digital coaxial (RCA) out.
Coaxial cable is Eurotronic RG 59B/U with unknown brand BNC connectors. The cable is used item and I bought it from a Asset & Recovery shop. As I don't have BNC-male RCA adapter, I used two wires directly conntected from one BNC connector to Phillips digital RCA out.
After double checking the board, setting up connections, plugging interconnect cable from DAC to ready-on amp, I switched power on. A "uhkk" sound from speaker announced me that the DAC got powered.
Pressed Play on the Phillips. Voila, sounds, music, .... and happy. It worked.
Cannot say anything about its performance as this is also the first time I listen music from this Phillips. I just borrowed it from my landlord to test the DAC.
But it worked. And I will need time to setle down my listening while the DAC is burned-in.
Thanks a lot, Peter, for great design kit and helps.
HT
Old 8th June 2011, 09:24 PM   #2803
autopoiesis is offline autopoiesis  Switzerland
autopoiesis's Avatar
Question Quick sanity check before installing r-cores in GCs (electrostatic screen connection)
Hi all,
I've received 2x 2x24V 300VA r-cores from Selectronic, to replace my buzzing Sedlbauers (AudioSector-chip amp kits, dacs, chassis)
The Sedlbauers have two input leads, and four out, whereas the r-cores have an additional 'electrostatic screen' (physically on the same side as the mains in), marked 'Ecran' here: http://www.selectronic.fr/upload/pro...logue/9-05.pdf
There's no guidance in the doc about the screen connection, so I presume it gets connected to input earth/chassis ground.
I have a single (star) ground point on the chassis - should I connect there, or at the mains inlet, from which I would also keep the existing ground?
Any guidance appreciated,
Steve
Dogs have masters; cats have staff
Old 9th June 2011, 04:21 PM   #2804
Connect the shield at the power entry module.
Old 11th June 2011, 07:09 PM   #2805
charlesbahr is offline charlesbahr
Default My 3875 premium kit sounds great, but I had a weird problem
I finally finished assembly of the kit in my box. I will not try Stainless Steel 304 again. It's too hard to cut.
Definitely a very nice sounding amp.
Less than 50 mV DC in the output channels with "open" inputs and volume at full.
It powers my speakers, and alternatively my Stax electrostatic headphones nicely. The sound is very clear, and my 15 yr old son thinks it's a lot better than our other stuff in the house. (his ears are better than mine)
When I was assembling it, I ran into a problem blowing fuses. I mounted the power supply board to an Aluminum angle, with screws running through the diode metal tab holes. Are those metal tabs NOT okay to be grounded? All I can tell is that it seems like that was the cause of blowing fuses. I went up to 6.3Amp slow blow fuses in my power input module.
2nd question: it is possible to increase the gain a little? I'm using a 20K log taper stereo pot for the input, and the R1, R2, etc. resistors as supplied in the kit.
Thanks for a fun experience.
Old 13th June 2011, 02:47 AM   #2806
Default PROBLEM: DAC is suddenly silent! Please help
Peter,
I've got problem with the DAC. It happened on last weekend when I moved my system from my room to the living room. After setting up everything for so called media center (DVD player, TV, TV Receiver, GC Amp, DAC, PSP, and pair of JBL 2080 and all proper connections), I tested and all worked fine.
Just yesterday evening, I bought a RCA-BNC adapter for DVD player coaxial digital out and used it for the BNC-BNC 75ohm coaxial cable to the DAC (before that, I used a direct wires connected from coaxial RCA output to the cable). After checking everything, I turned the DAC, then the Amp and tried to play a CD. But no sound came out.
Thought it might be amp problem, I tried direct link from DVDplayer's audio out. Sound is OK. But whenever I tried with DAC on, I got nothing.
I separated the DAC and measured voltage as suggested from your instruction diagram, I've got :
- 5.074V, 5.095V and 5.051V out at 3 AN8005s.
- 7.95V out at AN8008
- at TDA1543: 4.092V at 6, 2.101V at 7 and 4.11V at 8.
I thought that all outputs were fine comparing to the values on the diagram, then I connected the DAC back to my testing system: the PC's CDROM with digital out, GC and one speaker and they are separated from everything else (no TV, no computer, no PSP, no TV receiver). At first, it was not working - no sounds out from the speaker although I could listen to the music via my headphone plugged onto the CDROM. My brother found that the input on coaxial cable from CDROM end was shorted (it's very easily to occur like this as I used direct wires connecting from CDROM to coaxial cable on that end). Double checked and turned all on. Sound was back.
Then I attached DAC and Amp back to the media center. Turned all on. No sounds!!!!!
Doubted I'd made something wrong, I double checked again with everything, even with DAC's output voltages. All connections are OK and voltage values are exactly the same as above. But I cannot have the sound if DAC is attached. (Again, sound is OK with direct connect from source's audio out)
What is really happening? Did I accidently kill some components on the DAC's board? How do I fix this?
Many thanks,
HT
Old 14th June 2011, 10:04 AM   #2807
Smile DAC with Toslink
Peter,
One more question.
I want to include Toslink to the DAC. Can you provide the part number (e.g. Digikey or Farnell) of the additional components for Toslink module to the DAC?
The problem is that I cannot select the right part for optical receiver. Different values in nm confuse me.
Thank you very much.
HT
Old 14th June 2011, 01:52 PM   #2808
I don't think you can damage the DAC with a faulty cable as there are blocking caps at the input, maybe try a DAC with a different cable or different source.
For Toslink, you can use TORX177 or similar: Digi-Key - TORX177FT-ND (Manufacturer - TORX177(F,T))
Old 15th June 2011, 01:29 AM   #2809
Many thanks for quick reply.
I have tried the DAC with two sources: DVD player and CDROM with Digital out. First, I checked that they both work fine with their analog audio output connected to the Amp. Then I connected to their digital out to the DAC. No sound.
The interconnect cable from DAC to Amp works as I also use it for connecting from source's analog output to Amp.
I checked the coaxial cable. It is OK: no shortcut.
I wonder if any chance:
- the digital out from both sources had been damaged (!). I will borrow another DVD player for testing.
- any chip or cap on the DAC had been damaged. How can I measure and check if the onboard caps and chips are OK?
As I can detect a little electric shock when touching to the TV metal cover, I am wondering if any kind of such shock would kill a chip or a cap on the DAC. But I can still measure the right voltage values at the points you indicated on DAC's diagram.
Do I need an oscilloscope?
Thanks,
HT
Old 15th June 2011, 01:35 AM   #2810
Yes, you will need a scope to check if receiver chip works fine.
AudioSector-chip amp kits, dacs, chassisHide this!Advertise here!
