#241 |
Just short the caps with jumpers. If you will get undistorted signal, it means you can probably operate the DAC without those caps. Also, you might prefer the sound with the caps in place. The performance is largely dependant on output stage of your transport.
I must have mixed up the caps with ferites. You need two OsCons and two ferrites. I will send you one more OsCon
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#242 | |
#243 |
Thank you Peter!
I only was a bit worried that I did something wrong! George |
#244 |
Starting last week, a new LM4780 board is being shipped with the kits. The price didn't change yet, and will be the same untill weekend's over, after that it increases to $25/board.
The main upgrade here is improvement in PS section, so more options, including snubber, can be implemented. The idea is the same as with my LM3875 board, which I described here: http://www.diyaudio.com/forums/showt...429#post584429 Also the amp section is more flexible now, allowing to use all 3 possible conigurations: stereo, bridged and parallel.
#245 |
Comparing with previous version, the layout has been greatly simplified, mainly with regards to input ground and signal traces. The board has also bottom layer silk screening, so no more confusion where Zobel resistors should go
#246 |
Here's a pic of a stereo setup. Input and output (for each channel) are marked by IN and OUT (in a same outline), SG is for signal ground connection. There are two output ground (OG) hookup points (one for each channel).
The resistors values are as follows: R3/R5 680R R0/R4 22k R6/R7 1k (lower value, down to 200R can be used instead) R1/R2 22k No output resistors (0.1R) are used with stereo setup. Same configuration applies to bridge setup, as long as balanced source is connected. One board allows two separate stereo applications ( which can be suitable for bi amping) and one stereo bridged application. I will be able to supply 1/2 of the main board only as well (for single stereo application).
#247 |
Here's parallel setup. In this case R0 is not being used, as input shunt res. R4 is shared by both sections of the amp.
You only used left input IN and left SG. The output is taken from a center point now marked by OUT with two parallel lines).
#248 |
In order to tie both inputs together (before 1k resistors) a jumper needs to be installed, as pictured.
Also notice, that Rm is SMD resistor. So far, the miniature resistors were supplied for this location (10k), but I might switch to SMD in a future.
#249 |
I made it also possible to use T0-220 output resistors, as been suggested by our UK members
#250 |
I will be also able to supply premium components for both stereo/bridged and parallel configurations. Before any info is posted on a website, please contact me directly.
| Thread Tools | Search this Thread |
| Page generated in 0.12566 seconds (76.22% PHP - 23.78% MySQL) with 11 queries |
