The CD Transport - Page 12 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 9th November 2010, 02:23 PM   #111
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Peter, that's freakin' awesome! Great work as always! Beautiful!
I build, therefore I am.
Old 11th November 2010, 02:14 PM   #112
morpheous's Avatar
Send a message via Yahoo to morpheous
Hello,
I can not find the JVC RCEZ31
Is there an alternate ? Another Brand ?
Several JVC players look similar.
Francesco.
Old 11th November 2010, 05:24 PM   #113
Stealth is offline Stealth  Slovakia
Stealth's Avatar
Originally Posted by morpheous View Post
Hello,
Francesco.
Francesco
JVC has discontinued RC-EZ31 probably. JVC RC-EZ51 would be OK ..
Old 14th November 2010, 12:21 AM   #114
billo44 is offline billo44  United Kingdom
billo44's Avatar
Default Guide to identifying a donor
Here's my two yens worth of advice on how ID the sanyo laser unit discussed in this thread.
You can't usually do it online, you have to go into a shop where they have boomboxes out on display... with a small torch (flashlight).
Look for the CD mounting pedestal with a screwdriver hole for unscrewing the motor from the chassis, many units have this same spindle pedestal so don't take this point too seriously.
Shine the torch through the laser slot and first make sure there is a circuit board about 1 inch 25mm under the laser sled. Then look for the group of three small electrolytics and the three empty holes marked DOUT (digital out),
+5V, and GND, you can also see the connector for the door switch next to these three holes.
I could get away with this in Japan... being 6'4" and an ugly brute, the store assistants didnt give me any grief. They probably thought I was mad... they're probably right!
You might get a different reaction in your area!
This is just a guide, this is what I did and found a Sanyo boombox in Japan which was a suitable donor.
I can't take responsibility if you find a boombox that looks like this and isn't the right one. Just trying to help.
Good luck.
Bill
Old 15th November 2010, 01:33 PM   #115
morpheous's Avatar
Hi Billo4,
which model did you use? Do you have any picture of your Transport cd ?
Francesco.
Old 15th November 2010, 01:47 PM   #116
billo44's Avatar
Default Sanyo Donor
I posted pictures last month over on the longer original thread.
I don't want to pollute or dilute this thread.
Finally, an affordable CD Transport: the Shigaclone story
As far as I know this unit is not available outside of Japan and my local store tried to re-order but haven't been re-supplied yet.
Bill
Old 18th November 2010, 04:49 PM   #117
iwok is offline iwok  Poland
Hallo again,
my shigaclone is already working. Not finished yet, but able to play CDs. However I have small problem: constant voltage 0.53V on DOUT output. I`d appreciate any suggestions how to deal with it.
I did mod by Peter showed at the begining of this thread
Old 18th November 2010, 05:28 PM   #118
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
It's not a problem, it's normal. Usually there is a coupling cap in a DAC (0.01uF or similar) and you don't have to do anything. If DAC does not lock to your transport, install such coupling cap at the output.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 18th November 2010, 06:17 PM   #119
Is that not the SPDIF signal Peter?
Old 18th November 2010, 06:19 PM   #120
Yes, it is.
www.audiosector.com
CD PRO 2 - The making of a high end CD Transport Peter Daniel Digital Source 439 12th January 2010 09:09 PM
Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. Spasticteapot Swap Meet 0 7th October 2006 09:12 PM
CD Player vs. CD Transport using CD-PRO2 module tomchaoda Digital Source 27 22nd May 2004 09:29 AM
CD-ROM as a CD Transport ruangrit Digital Source 4 29th April 2003 02:34 PM
Copyright ©1999-2017 diyAudio
