| Audio Sector Kits & PC boards from AudioSector |
#11 |
Have you tried installing something else in the USB port on the computer, to make sure it's working? I've had USB ports go bad before and it's an easy thing to check.
#12 |
It's rarely a hardware problem, most likely it's related to software/interface. Some people experienced similar problems in a past, especially after sudden power disruption during a storm, etc.
Switch everything off, wait an hour or so, connect USB cable to a DAC and power on the DAC first. Then power on computer. If you can't make it work, ship it to me and I will check it out. For more info on system configuration, I recommend this link: The Art of building Computer Transports
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#13 |
Yes, tried a couple other, different DACs, back to using one of them now.
Tried other USB ports. Tried a different computer. Tried power on to DAC first, computer off for an hour, a day, a couple days. There have been sudden power disruptions from storms. Maybe need a UPS for this circuit? I'll ck out the website, & if I still can't figure out anything ship it to you (Peter), Thanks again, r |
#14 |
Just today I received the SPDF dac and from the first hour it sounds marvelous...
I think that is the best DAC in my system since today!!.. It excels my Lavry DA 10 dac very easily in all points Thanks again for this "best buy" product Manolis
#15 |
not politcally affiliated
Have had my kit running for awhile. Lost the schematic,
Can someone tell me what resistor to put and where for the LED to work? Thanks!
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE |
#16 |
Put the LED across one of those large black caps. It is approx 12V there and here's how to calculate the series resistor: LED calculator for single LEDs
#17 |
Hi
I am currently using the USB Dac. I would like to know is there any way to keep the USB input but modify to balanced output as I am going to up grade my entire stereo system from single ended to balanced. Please advice. |
#18 |
Yes, you can easily do that. Please see attached schematic posted by dddac, of course you don't need to use 12x TDA1543, but a single one:
#19 |
Hi Peter
Thank you for posting the schematic. It is very interesting. Do you have the link for me to take a look of the complete dddac article? Best Regards |
#20 |
Hi Peter
I got this schematic from the web it looks very similar to the one you posted but no output transformers. Please comment. |
| Fs: Audiosector Nos Dac | r8833 | Swap Meet | 6 | 14th February 2009 02:59 AM |
| Chipamp PS audiosector PS | Ted205 | Chip Amps | 5 | 11th August 2008 01:59 PM |
| AudioSector NOS DAC $225 obo | nodiak | Swap Meet | 2 | 8th November 2007 05:10 PM |
| Audiosector NOS Dac | Darrell Morgan | Digital Source | 7 | 8th August 2007 02:55 AM |
| audiosector dac | karma | Chip Amps | 3 | 7th December 2005 01:04 AM |
