| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#251 |
#252 |
diyAudio Chief Moderator
Maybe a typo. Anyway, if you can get the Quad II down to 0.7V RMS sensitivity with that mod, I simulated a phono + DCB1 combo idea that could drive most of valve amps directly when fed from a 0.5mV MC cart, with low THD second gain stage, and passive RIAA filter.
#254 |
Any OpAmp could just work. There is both sides buffering and capacitive coupling for Vo offset in the CCT. It just depends on the noise density you can afford in a system, given the speaker's sensitivity, main amp's gain, your priorities etc. Although some parts can be very nice to your ears, here we need an inverting 43dB 2nd gain stage, and the 470 Ohm R9 is the interstage buffering 10xB1Ro limit for driving. Which isn't optimal for noise, but necessary in this case. With circa 1nVrtHz En OpAmps like LT1028A there is roughly a 2.9nVrtHz En reflection from the output contribution for chosen gain and resistors, calculating with datasheet En&In 1kHz, R9=2.74nV, R10 33nV, G=145. Now your proposition has 2.7nVrtHz natively, and goes 3.93nVrtHz in this configuration @ 1kHz. Check in your system for hiss VS tone and choose.
#256 |
Hi electronic Hi-Fi experts,
I have built some boards for Mads K's Atlantic RIAA, and am finally getting around to building a regulated power supply. I have found some kits for regs on eBay, from a trusted seller Jims_Audio_Store in Hong Kong who does reasonable low priced kits that I've used before. I need 2x27v DC for two mono-blocked RIAA circuits. I need something quite cheap, but not lousy quality either and I saw this: I know it may have some superficial noise level above an ultra-simple reg using K-170 fets, but do you think this will be reasonably satisfactory for a year until I have more money to upgrade? Also, how many mA is this circuit likely to draw? I'd like as small a transformer as I can get away with but don't know what that's likely to be. Many thanks for all your help Lucas
Lucas |
#258 |
Hi
can i make this RIAA PRE play tru balance ? i won some more in sound ? |
#259 |
Hi
So, it took me 2 years for my circles to take there places ![]() I was first interrested in Salas and wrenchone and their work. I got a hint from Salas about this allaround "pacific style" phono amp (allmost two years ago). In the meantime I have fiddled with a TetraOne kit from Tubecad (John Broskie) which sound incredible... Thats another thread though .. when I'm "There". ![]() To the point.... At last I got big time trigged on the Norwegian guy Mad_K and his enthusiastic approach (this thread) with the simplest of this schematics of them all, without the cascode and also, no talk about high input capacitance for MM and so forth ... This very thread's first post. I built it last week, in about two hours (veroboard) and .. it sounded really good and lively. I had a PSU with slightly less then 1mV ripple and I had problems with oscillations. If I put my finger on the right channels signal line it dissapeared :-| My finger was numbed that evening .... The sound was incredible! I reckoned it was that good I have to try some more. I'm sorry but I have to get this out of my system and bring my experience off to you in a hurry, even before I have any schematics of my approach avalable ftm. ![]() This Phono amp i incredible good ! I stomp my foot to the floor and changes Vinyl LP's fast ... I have to go trough my collection again. Amasing! Theres music and sounds I never have heard before! Because I'm a electronic technician and measuring metrology guy, I have f.e. also meaured the input capacitance to around 117 pF which, together with a normal cable around 100pF is OK with a MM measuring around 400mH. So you maybe wont need the cascode approach Salas mentioned here and there in thoose long threads. I use the SK170GR FET. I have also measured the THD to be exactly -78dB on both channels, This is the second order THD. There is also a small peak third order way down... then it's all clean! Amasing for a NFB circuit. I have a very good PSU now and also some LC filtering per stage and also starground for every stage as there own. Exaggerated ... and totally silent when there is no music. As I have put my cheek out I have to draw my version schematic to show you, I know But it will take some more time.Anyhow... Try to build this one as the first post in this thred and you will have something which will take your time for a while
Cheers// Ove |
#260 |
I have Mad K's Atlantis.
Its a fully bjt cascoded, and bjt cascode followed, 2 stage jfet base cct, with passive Riaa. (Thanks Salas ) It's single Ended, zero feedback. Class A (Pulls 27mA, but the hot-rodded Salas shunt reg I have now bumps that up to 200mA).I believe Mads K is using this one from 2007 in his system too. It is very nice indeed.
Lucas |
| Suggestions for RIAA preamp? | coldcathode | Tubes / Valves | 17 | 7th March 2009 08:32 PM |
| tube preamp RIAA | radiodieg | Tubes / Valves | 5 | 3rd September 2008 02:36 PM |
| Ultrasimple MM/MC RIAA Preamp mkIII | GlidingDutchman | Analogue Source | 5 | 2nd July 2008 08:42 PM |
| RIAA Preamp | Justcallmedad | Solid State | 4 | 2nd September 2005 02:52 AM |
| ultrasimple mm/mc riaa preamp | Mad_K | Analogue Source | 109 | 31st July 2004 07:34 PM |
| Page generated in 0.15630 seconds (78.32% PHP - 21.68% MySQL) with 11 queries |
