The Incredible Technics SP-10 Thread
For comparisons sake, here,s my JVC QL-10 guts
37 caps to replace!
It works well with out doing anything to it, but I can't leave well enough alone
42 pounds with plinth.
Just picked up a desoldering station. Tired of the usual way all those years!
David
Neat!
A suggestion - ans it will take the QL-10 to the next level - remove the transformer and place it in it's own case, even it it needs a complicated umbilical, it's completely worth it, I've never removed a transformer form a 'table and it not sound anything but wonderful. A genuine enhancement.
The one there is sealed in its own steel enclosure and doesn't hum and has no consequences that would warrant taking it out as of yet.
However isolating it is always a good idea. I generally prefer belt drives for my main TT, but it's nice to compare both ideas once in awhile for a reality check.
David
I had belt drive for years. Thorens, Rega, Linn.
For me, I'll simply say that I will never, ever go back. (And that statement is made on my experience modding the SL-1200, I haven't yet heard the SP-10!)
Zen Mod - Ah. Perhaps. I don't think damping the chassis would be heplful, but perhaps it would on the metal bottom cover, and on the motor like you suggest.
zeonrider - Between my SL-1200 and the SP-10? I think there will be, as the overall design is actually quite different - my SL- is suspended (Isonoes) and medium mass, the SP- will be high mass with solid feet. I would love to get an identical arm (Graham 2.2) for the SP- but I just don't have that kind of money in my audio budget for a long while...
Hopefully they arrived intact. 😀
Repair that PSU before plugging it in.. LOL
Yeah, I figured out that part. 😀 jp and Jim are helping me out with the plinths. I'm going to dig into the electronics, and maybe do something with the bearing lubrication if that looks like something that needs improving (made a big difference in my VPI). Doing new mats might be interesting- I have some ideas and the ability to compression mold rubber.
I will tell the world publicly that I now have a man-crush on Kevin.
Now I feel like I should rush out and buy another! 🙂 Mine's purdy though...
attachment.php
And is the source of my original comment about it being about time I could help him spend some money, as he's the one that talked me in to buying this one.
I adjusted the phase tracking today. Using a DSO, I had to stop acquisition to measure as wave T isn't at the same frequency as wave S, so it wasn't showing consistently and there was some noise causing both waves to jump around a teeny bit.
This is at 33 RPM - it's supposed to be 6.3 +/- 0.2ms, and we're at 5.95ms.
attachment.php
And adjusted to 6.30ms
attachment.php
45 RPM isn't adjusted, but should be 4.7 +/- 1.3ms. I'm at 4.25ms, so we're good.
attachment.php
Last was 78 RPM, which was significantly off. The right cursor is where it's supposed to be - 2.70 +/- 0.1ms. I believe it was 1.6ms or so.
attachment.php
And here it is adjust to 1.68ms. The control on this one is rather touchy.
attachment.php
Last, here's what things look like on an analog scope.
attachment.php
Next, service the bearing and start figuring out a plinth 🙂
JP - looks great! I'm glad it's straightforward to set after the re-cap.
SY - user510 sells Torlon bearing caps that he makes, JP and I have got them, haven't yet installed. Also will get a SiN ceramic thrust ball, as it has lots of cool factor.
Here's a couple of "before" pix. One of the tables is cosmetically a disaster- looks like someone spilled a caustic substance on it. The other is about like the ones 6L6 is starting with. So the sandblasting cabinet is going to get some use this week.
