The Incredible Technics SP-10 Thread
Old 9th September 2014, 11:16 PM   #11
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Everyone needs a machinist friend next door
Old 9th September 2014, 11:28 PM   #12
6L6 is online now 6L6  United States
6L6's Avatar
Originally Posted by SY View Post
Did I mention how much I hate you?
What am I going to do with two of these? Seriously...
And remember, I also have a fantastically good sounding, completely tweaked SL-1200...
As for the SP-10, I never intended on having two, the ebay seller mentioned he had another, (the mate of the first one, both from a radio station somewhere) that it was uglier, and he wasn't sure if it would do well on auction. (And after seeing it, I agree.) Anyway, he sold it for a price good enough that I couldn't really refuse, and now hopefully will have 2 when this process is complete.
And at that point, I'll sell one. . Interested?
Anyway, all ya'll ain't seen nuthin' yet...
Old 9th September 2014, 11:29 PM   #13
On Hiatus
SY's Avatar
I'll be in the market after my ex-wife and her lawyer have the courtesy and consideration to die.
It's a 'table I've always wanted.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 9th September 2014, 11:35 PM   #14
epistaxsis is offline epistaxsis  United Kingdom
And it's good to see that you've finally seen the light and got a decent technics record player
Have fun with the builds!
Old 10th September 2014, 12:28 AM   #15
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Originally Posted by 6L6 View Post
Unfortunately the platter from the 'nicer' table got dropped in the process, my fault, and got a few dings in it. This is the worst one.
I'm still probably going to go back and give the platters another round of cleaning up, I didn't bring all the compounds I wanted to try, and also ran out of time. But as they stand right now, they look much, much better than when I started.
Shame you dropped it. Ask your buddy if he can skim the platter rim on the lathe, and get most of the "ding" (or dings) out. You have to use a low rpm thou, otherwise the platter will ring like crazy, and you'll get a lousy finish. Get the rest out with a big cotton buffing wheel and some compound.
jeff
Old 10th September 2014, 01:27 AM   #16
kevinkr's Avatar
Very cool, you're off to a good start.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 10th September 2014, 01:30 AM   #17
JP is offline JP  United States
JP's Avatar
Glad I could help you spend money for a change :P
Old 10th September 2014, 07:45 AM   #18
soundofvoid is offline soundofvoid  Greece
jeff
I agree.If this is the worst then you can easily skim it off by lowering the edge by a couple mm...(metric guy)!
After you're done and while it's spining rub it with some scotch-brite (take your time with the difficult places) and it will sparkle as new.
Actually do both again because i can see some un-worked areas...
As for the warm water and soap solution...i prefer putting back the oils in an old rubber mat that taking them out.If they do need a bath, immediately after washing them use vaseline or paraffin oil to moisture the rubber.
Let it soak for an hour and gently hand-rub it off.
Trust me, it works.
soundofvoid
Old 10th September 2014, 08:29 AM   #19
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
I wouldn't bother with skimming edge of platter , because of minor cosmetic thingie (even if I really have lathe in my own garage)
it's small , and mass is still there
besides - that platter is now having increased level of personality
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th September 2014, 02:30 PM   #20
6L6's Avatar
I won't skim the edge - as Choky says, it's personality now, and will be a reminder of this project.
That said, I will most likely go back and clean them up more at some point.
But that can wait, as it is much more important to build PSUs for these guys, and re-cap the drive PCB. Once that's done, I will get the drive adjusted and tuned-up to spec, and then disassemble everything, and re-finish the chassis of both table somehow.
I've ordered new Torlon thrust bearing plate caps from user510 - sp10mkII_pad Much, much more info, here -- sp10 brg
Necessary? Probably not, but I like the idea of overhauling the wear points.
The Incredible Technics SP-10 ThreadHide this!Advertise here!
Technics SP 10 Speed Problems rollinr Analogue Source 29 27th October 2017 09:05 AM
Technics SP-10 Doesn't Spin breadhead Analogue Source 6 26th October 2014 11:09 PM
Cheap oscilloscope for setting up a Technics SP-10 johnm Analogue Source 22 28th June 2011 07:47 PM
Technics SP-10 speed problems Stefanoo Analogue Source 3 17th August 2008 10:05 PM
Technics SP-10 MKII pitch control peterb Analogue Source 6 28th March 2004 01:29 PM
