Paradise Builders
Paradise Builders
Old 6th February 2013, 06:51 PM   #1381
Doppelkopf is offline Doppelkopf  Germany
Originally Posted by Doppelkopf View Post
I think , like Ralf do , your Highoutput MC is not the right thing for paradise .
I would try an cheap/used or lent Low MC .
It was not designed for high output carts but it works wondefully with a DL160 with 1.6mv output, so that does not seem to be the problem.
Testing a Low MC could isolate the problem .
Maybe 1.6mV is OK , 2mV is too much ?
greatings , Dirk
Old 6th February 2013, 07:02 PM   #1382
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Paradise Builders
Even a high output cart does not always put out full voltage.
If playing low level passages, even a high output cart would output low voltages, so the "possible" clipping would only happen at large vinyl modulations.
RC
Old 6th February 2013, 08:22 PM   #1383
Pepperman is offline Pepperman  Germany
In my opinion a HO MC works better on a low impedance MC input underneath 300 OHM. I would try something between 100 and 300 OHM across the input.
Old 6th February 2013, 08:30 PM   #1384
Joachim Gerhard is online now Joachim Gerhard  Germany
Joachim Gerhard's Avatar
2mV at the input of the Paradise gives somewhat more then 2V at the output.
The only thing that goes down is overload margin. Say there is a music peak cut at plus 20dB ( x 10 ). The paradise will put out 20V but that is at the edge of what it can handle.
This will only happen on a few extreme records, say from RR or Telarc.
I whould say a cart with 2mV at 5cm-sec is the maximum i would use with the Paradise.
Old 6th February 2013, 08:33 PM   #1385
If you have a fast true RMS meter you could put it behind the Paradise and measure with a
very dynamic record what actually happens. You can also put a scope there.
Overloading the Paradise is unlikely but what will your power amp do with 20V P-P input ?
You really need an attenuator behind the Paradise in those cases.
Old 6th February 2013, 09:48 PM   #1386
nhinstruments
RCruz's Avatar
Paradise Builders
RC
Old 7th February 2013, 01:01 AM   #1387
hesener is offline hesener  Germany
Paradise Builders
Default updated assembly guide
Hi folks, here the updated assembly guide, now also in german. Have fun....
File Type: pdf Paradise R3 assembly guide deutsch.pdf (813.9 KB, 122 views)
Old 7th February 2013, 02:15 AM   #1388
PierreQuiRoule is offline PierreQuiRoule  Canada
PierreQuiRoule's Avatar
Paradise Builders
Just thought I would share a short progress report. The boards are complete. I tested one of the power supplies and observed oscillations at 3 MHz. The heat sink got fairly hot. Will order and add the four caps next. I am glad an easy fix has been found.
Pierre
Old 7th February 2013, 02:59 PM   #1389
Abraxas336 is offline Abraxas336  Europe
Abraxas336's Avatar
Many thanks Alfred. I would like to support the other requests regarding your signature - if you could keep links to the most recent guides in your signature that would make it a lot easier to find. Or may be it could be updated in the first post of this thread.
Sven
Gruenschnabel
Old 7th February 2013, 03:58 PM   #1390
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
I'll add my thanks too......this continual up-dating is excellent and much appreciated. I simply have a Paradise folder and as each new up-date appears I download and file the .pdf ....easy. I then put the superseded version in the trash can. Simple.
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1376 12th August 2017 02:27 PM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 03:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 07:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 05:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 11:19 PM
