| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#1121 | |
#1122 | |
This would save loads of time fiddling with the offset... And will form caps faster |
#1123 |
#1124 |
Hi guys, could not wait . Finally plug it in . Loading resistor 150R . Catridge mod esc stylus midas body 103, apparition tonearm N GARRARD 301. The sound is relax but detailed and tonality is very good. The main problem is hum in both chanels .
quan |
#1125 |
Look at grounding Board do not pick up much so got to be cables
#1126 |
Hi Sandro, i will need to study the grounding scheme .
#1127 |
#1128 |
If someone wants to DIY a thing that is so complex as this one, he absolutely needs a scope. DMM is good quite for nothing, it is only an elementary tool. Don't believe those who tell you that as a DIYer you do not need a scope.
You do not need to buy an expensive instrument. It can be just a USB device like this: USBscope50 1Gsps/75Mhz USB pen-style DSO (Digital Storage Oscilloscope), Synchrotech But even stand alone instruments are not expensive: Uni-Trend Group Limited Every serious DIYer should have a scope, otherwise his results are just accidental.
Pavel Macura http://www.linkedin.com/pub/pavel-macura/4/783/637 http://web.telecom.cz/macura/audiopage.html |
#1129 |
Point taken.
#1130 |
Updated assembly guide with the latest proposals on compensating the CCS in the power supply section if needed, and the RIAA time constants.
| Paradise phono stage | hesener | Group Buys | 1018 | 3rd May 2013 08:56 AM |
| DIY Paradise - Any good to buy from? | gingerpimp0069 | Vendor's Bazaar | 7 | 21st June 2007 02:07 PM |
| DIY Paradise Charlize | Jolojl | Swap Meet | 7 | 7th December 2006 06:42 AM |
| Diy Paradise! | alexmoose | Tubes / Valves | 3 | 24th July 2006 04:37 AM |
| Another way to paradise ? | Bernhard | Pass Labs | 3 | 8th August 2003 10:19 PM |
