Old 5th January 2012, 01:02 AM   #11
IMO, Hagerman has some good stuff on inverse networks here. One thing I've found is that measuring RIAA accuracy directly using signals and meters if fraught with difficulty. The dynamic range required is large and if the meter switches ranges you lose accuracy. The best way would be with a ratio transformer, but not many have those hanging about in the lab. Thus, a carefully measured inverse network is best.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 5th January 2012, 05:26 AM   #12
Bonsai is offline Bonsai  Taiwan
Bonsai's Avatar
What about a sound card followed by an attenuator network to generate the inverse curve? I've done (and do) embedded programming, but nothing on the PC but I think this would be an absolute cinch with VB - generate and measure all out of one card. Maybe there's already some software out there, and if not, we should suggest it to RightMark.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 5th January 2012, 08:40 AM   #13
h_a is offline h_a  Europe
h_a's Avatar
If one hooks the circuit up to a pc, one can always do a frequency sweep and compare that to a calculated RIAA response (created in Excel with the measured gain at 1kHz). The comparison is not real-time, but that's usually not necessary as fine-tuning the RIAA is not a matter of changing single component values (as Lipshitz discusses at length ;-) ).
Thanks for the link to inverse RIAAs, might come handy though.
I don't know that I can neccessarily change it
Well, if you set R3 to zero, it has to be zero all the time. I don't see why a value for R3 is calculated at all. If you look e.g. at Table 3a, you see that R3 and R0 always show up together. Setting R3 to zero, only R0 remains in the equations, so there remains in fact no relation one could use to calculate R3.
Old 5th January 2012, 09:19 PM   #14
Bonsai, that seems like a reasonable approach, assuming the s/n ratio is good enough and the attenuator is chosen wisely. I bring up the issue because people get interested in fractional dB errors, and the measurement isn't trivial given the combination of small signal levels, dynamic range and frequency range.
Old 5th January 2012, 11:19 PM   #15
scott wurcer's Avatar
I use an inverse RIAA 1/10th octave multitone signal and a sound card which you can average as long as you want. SoX will do it all for free.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 6th January 2012, 10:15 AM   #16
Bonsai's Avatar
Thanks Scott - I will take a look. Who/what is SoX?
bonsai
Old 6th January 2012, 12:51 PM   #17
h_a's Avatar
Sure, that's certainly most practical!
I guess Scott means Sound eXchange, a powerfull command-line tool
SoX - Sound eXchange | HomePage
Old 6th January 2012, 01:31 PM   #18
Hennie is offline Hennie  South Africa
The open loop transfer function of Self's circuit will influence the component values required in the feedback network. In the case of an op amp the open loop gain is high enough for it to be ignored, but not here.
You can try a single dominant pole approximation of the open loop transfer function with the actual LF gain and the actual dominant pole, and calculate the required feedback values accordingly. I did that many years ago, but without taking the open loop gain into account I just could not get an accurate RIAA curve, especially at the HF end of the RIAA CURVE IIRC. By taking the open loop transfer function into account, the required target transfer function was met satisfactorily. It might have required an extra component in the feedback network, I can't remember exactly
It is perhaps easier to simulate in Spice until you get the target curve right.
Old 7th January 2012, 02:52 PM   #19
While we're on the topic of simple phono sections, here's the circuit used in the old Ace Audio preamp from around '74. It sounded quite good, though I've no idea how accurate it is. They also had a line stage, but eliminated it for the "zero distortion" version. From my archives.
Old 7th January 2012, 07:19 PM   #20
gk7 is offline gk7  Europe
I was not aware that sox can do an inverse RIAA. The manpage says "riaa Apply RIAA vinyl playback equalisation." How would you invert that ?
Georg
RIAA? Osvaldo de Banfield Solid State 2 21st December 2011 02:54 PM
Marantz CD63 KI SIG, Error 12, Sled Error problem sisik Digital Source 1 9th November 2008 03:12 PM
RIAA help philipbarrett Tubes / Valves 4 22nd March 2005 01:55 PM
Whats worse, 1db error in response curve or a phase error of 6? primalsea Multi-Way 5 13th May 2003 01:24 AM
Page generated in 0.11103 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
