| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#4671 |
as always.. simple circuits sound best, but they may require good household to do so....
#4672 |
Yes, keep it simple AND clean.
#4673 |
how is the mounting coming along....will you soon power it up..??
#4674 |
Maybe I hear some sarcasm in there? But I cleared (by the people of ATL) to help you identify the current 'best' circuit, it’s the attached one (circuit M in the file).
Signature Transresistance Current-Feedback BIGBT Amplifier; Push -->>{{ }}<<-- there.
#4675 | |
New Coldplay CD on the spinner. I have increased the track size to 2mm Still using the 5 mm foot print for 100nF Caps I have added the top layer Ground plane (This can be tied up to proper ground on any of the pins For clarity I have removed the bottom layer cooper poor area And added a few pads for the output capacitors The only concern I have is the length of the (highlighted) darker track. Edit time was about a couple of minutes if that so no problems in any changes On the caps the 5 mm size may be a limit to what is available If this was 22.5 there are 4 or 5 types of MKP caps available from the like of Farnell. Is not trouble at all to make any changes as I said before it is an honour to be here. PS I could not use color as PDF size is 160Kb If you need any DXF Gerbers or such I will email |
#4676 | |
I am gone order lots of them
#4677 |
I like the layout better and better too. And all done by hand. For me it can be the bigger sized caps. You get them in PP quality.
No Frans, i had a gut feeling that it should be simple. I have nothing against children, quite the contrary, they have a lot of that we have lost and they are honest. MiiB, i am running out of well matched transistors. The ones from Frans where very good but the ones from Reichelt did not match at all. I have now ordered some from Fairchild. They invented the modern planar epitaxial transistor so i hope they have some pride left. |
#4679 |
Another "noob" question.... In the central area of the pcb we have the leds that set voltage for the opamp.
The leds are identified by a small circle with two triangles in one of the legs... are these markings pointing to the anode (+) ?
RC |
#4680 |
The marking is the long leg.
27 Ohm is fine. Noise goes down, distortion goes up VERY little. We had 20 Ohm in the beginning and that worked too. |
