Old 9th May 2011, 07:48 PM   #201
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
There will be many capacitor types to test. One very good interstage will be K72 0.047u 500V Teflon also. And other types for the Riaa as well as small value changes from 0.015-0.0155u to evaluate. Always >250VDC all signal caps don't forget.
P.S. Any under the hood pictures will help people visualise what we talked about bus bar GND and fixing.
Old 9th May 2011, 08:42 PM   #202
OK,
It was easier to sketch it than photograph. That would have meant turning it off.....
So bear in mind that the layout used here is most likely not ideal. I used it because it suited a case I already had (holes drilled etc). So I'm sure having the 4 valves nearer one another or laid out in a different way would be better.
So, the basic premise is that 1 long bar runs along the lenght of the 4 valves. Low current grounds (inputs and input valve cathodes) are connected right at one end. Next up along are all the RIAA grounds (close to the input grounds) and then right at the far end of the bar I have connected the PSU ground, output grounds, heater ground, connection to chassis and the output cathode grounds. The shields on the 2 x 6N2 are along the bar.
As I said, I'm sure there are better ways, but I now have very low hum.
http://www.diyaudio.com/forums/attac...1&d=1304973716
Fran
Old 9th May 2011, 09:18 PM   #203
Salas's Avatar
Thanks Fran, that will help the other guys next. Kraftwerk Man Machine LP?
Old 9th May 2011, 09:26 PM   #204
Yup - moving on to transeurope express next, with coltrane ballads after that. Heatsinks are pretty toasty... up at 60 id guess.
I've learned a lot on this build so far, I feel like going back and rewiring a few other amps now!
Old 9th May 2011, 09:32 PM   #205
Salas's Avatar
I have seen them on their Mix comeback tour in Liverpool 20yrs ago. TEE was hypnotic with the wheels revolution video in the classic theatre decor.
After making a 60dB gain valve circuit quiet, what you learn is a boon for working on HV & vacuum. What is your ICCS? Maybe you can shave off some? High heater regs sink temp too?
Old 9th May 2011, 09:36 PM   #206
They were here some years back but I missed it. They played a small concert which was meant to have been great..
coltrane ditched for sketches of Spain + glass of rioja (bad for Monday night!)
Fran
Old 9th May 2011, 09:41 PM   #207
Salas's Avatar
No! You make Merlin want to make one too.
Old 9th May 2011, 09:50 PM   #208
sounds even better after a glass!
R1 is 47r...... so maybe I could shave a bit off. Heater regs have puny sinks anyway so I'm probably going to change those anyway. I have some bigger ones I could use. It's just that when it's boxed up there will probably be 10 degree more heat easily.
Fran
Old 9th May 2011, 09:55 PM   #209
Salas's Avatar
See your voltage drop across the 47R, then divide by 47R. That is the CCS current. Two itch channels are draining ~10mA. See to have 30-35mA CCS total. 20-25mA are OK for the reg to consume internally for proper Zo. Each 10mA extra spare is 3W dissipation @ 300V on the IRF840...
Old 9th May 2011, 10:56 PM   #210
taniknight's Avatar
Just to clear something up, from Salas' advise on bar grounding, I thought that the bar should only see chassis ground at the input end and power ground at the output end.
Originally Posted by Salas View Post
On a bar we ground at the input side to chassis only, and we go from lighter to heavier currents in a row on it ending at PSU. Something must be mixing there most likely.
However, Fran's sketch shows chassis ground at the PSU grounded end. Naturally, Fran, if it sounds good, it is good. I just thought I'd make sure I hadn't missed something.
Tani.
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
