Sorry you are right, I forgot HV for Itch RIAA, but for 15nF Marko has 0.015uF 10% tol. 400V, TexCap 200GGS.
Buying only one value from 10% stock, paying postage and matching fees for just two capacitors and then mixing them with other makes in the same filter? Does not sound very practical IMHO.
I bought togheter Ricardo & Massimo 23 caps 15nF FT-1 & no one was really 15nF all rated 200V like all FT-1 so can use with Itch, FT-3 rated 600V don't have 15nF & 47nF values, could you recommend other Russian teflon types 15nF & 47nF matched pairs with Voltage rated for Itch?
N.B. I don't have Mark commission.
Sorry Salas both values Auricaps 600V are 10% not 1%, see caps manufacturer link:audience : capacitors : auricap
P.S. I like Auricap too.
I still do not understand the difference between 1% and 10% parts once we are making sure they are matched....
Problem is we can't find something standard for 1-2% tolerance and 250V, new, generally available, to include in the BOM. Finding some way with a dealer to measure and send from small NOS 5-10% stock or new, is not something defined to include in a BOM, especially future wise.
The tolerance may not tell the whole story, generally the more tightly toleranced the part is designed to be, the better the stability over time and temperature. An extreme example might be a pair of 10% carbon comp resistors matched to 1% or better, a few years on they won't be. (The physical character of the carbon slurry used in these resistors is affected by temperature, moisture and some specific aging mechanisms.) Similar mechanisms also exist in some types of capacitors as a result of the care taken in the construction, choice of materials used, and packaging..
Generally good film capacitors are stable and may be matched to tighter tolerances, starting with a 5% part or better is generally a good idea.. 2% tolerance films are hard to find, but do exist.
ICEL MKP 15nF 1% 630VDC
1 pc 1,72 EUR
10pcs 1,49 EUR
50pcs 1,28 EUR
100pcs 1,05 EUR
+ VAT + shipping
https://www1.elfa.se/elfa3~eu_en/elfa/init.do?item=65-456-44&toc=18844
ICEL MKP 47nF 1% 630VDC
1pc 1,97 EUR
10pcs 1,72 EUR
50 pcs 1,47 EUR
100 pcs 1,20 EUR
+ VAT + shipping
https://www.elfa.se/elfa3~eu_en/elfa/init.do?item=65-457-01&toc=18844
I will buy, if there is more people interested to buy I can share my order, interested people please let me know?
1 pc 1,72 EUR
10pcs 1,49 EUR
50pcs 1,28 EUR
100pcs 1,05 EUR
+ VAT + shipping
1pc 1,97 EUR
10pcs 1,72 EUR
50 pcs 1,47 EUR
100 pcs 1,20 EUR
+ VAT + shipping
I have seen many such capacitors in Jadis gear. Could have been the MKT ones though. They have also in the gamut the 0.1u 250V ones in the mu followers, they can be 10%. Same for the 2.2u output and 4.7u RC decoupler. And they have SCR 5% also.
P.S. Do they accept Paypal?
- Analogue Source
- Valve Itch phono
