Lightspeed Attenuator a new passive preamp - Page 437 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 6th January 2012, 11:13 PM   #4361
udailey is offline udailey  United States
NSL32SR2 needs nowhere near 20mA to hit lower than 40. Did it 12 times today with 12 different NSL32SR2 and only 10mA. The SR2 and SR2S are in fact the same device. After manufacturing some are bagged and some are matched at around 100R to 200R and if they are within 10% of each other they are given an 'S' badge and a letter indicating into which 10% between 100 and 200 they fell into. Also all on the datasheet. However my information does not come to me via the datasheet but from several discussions with the vice president of silonex and their quality control engineer. Obviously I have performed my own experiments on many of these devices. Around 9000 of them now.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 6th January 2012, 11:49 PM   #4362
georgehifi's Avatar
Send a message via MSN to georgehifi
Believe what you will, but these are the facts below, and are verified to me by Fred P. Rohrbacher V.P. & General Manager of Silonex a Casco Company, with who I've had many a email disscussion with over the last 6-7 years.
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 7th January 2012, 07:41 AM   #4363
Wayne Parham's Avatar
Originally Posted by georgehifi View Post
...you will also get better logarithmic feel to the volume instead of nothing at the start till you get to 12 o'clock or too much at the start and can't get passed 8 o'clock...
Curious what you are talking about here. What do you mean when you say "you will get better logarithmic feel to the volume instead of nothing at the start til you get to 12 o'clock"?
I ask because a true logarithmic curve is exactly that. It's high attenuation for most of the entry ramp, then rapidly reduced attenuation past the halfway point. This is what log scale means. I must be misunderstanding you somehow.
What do you use for a volume control to drive the LDRs in your circuit?
Logarithmic Scale
Visit the π Speakers website
High-quality audiophile loudspeakers and kits
Old 7th January 2012, 10:06 AM   #4364
georgehifi's Avatar
Exactly what it should be smooth and progressive from zero to 12o'clock then quickly accelerating the level from 12o'clock onwards. (logarithmic). That's what the matched NSL32SR2S quads do with a 100k dual log pot controling the 5vdc to the led's through 100ohm resistors.
Cheers George
Old 7th January 2012, 11:21 AM   #4365
Andrew:
Like I have said all along more times than I care too now (to put it less diplomatically), you will get better lower levels if you use the NSL32SR2S, and when quad matched you will also get better logarithmic feel to the volume instead of nothing at the start till you get to 12 o'clock or too much at the start and can't get passed 8 o'clock. And also more stable impedances which I believe gives a better more consistant sound at different levels also, over the NSL32SR2 or the NSL32SR3. As you have typically 40ohms min value with the NSL32SR2S where the others have well over 100ohms and if anyone pushes these harder than 20mA you will over time end up with a dead led/ldr and that's a given.
Cheers George
Where in there, is the data, to show that "Quad Matching" results in "Lower Minimum Volume"?
I am not referring to any of your other claims.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 7th January 2012, 12:21 PM   #4366
georgehifi's Avatar
Andrew stop trying to twist things, you must have a serious weed up your ****. I stated in post 4358. "This is why I use quad matched sets of the NSL32SR2S, to get lower min volume to get better logarithmic feel to the volume and better channel balance."
The data shows the NSL32SR2S has a far lower typical impedance (40ohm) at 20mA led current than the NSL32SR2 or the NSL32SR3 which are over 100ohms typically.
Cheers George
Old 7th January 2012, 12:30 PM   #4367
Georgehifi,
Since you have replied with 4posts since I asked about that claim, are you deliberately avoiding offering any justification for your claim that "Quad" matching "lowers the minimum volume"?
If you don't show how you have arrived at that, then I'll simply have to conclude that my first impression was correct. Quad matching does not lower minimum volume.
regards Andrew T.
Old 7th January 2012, 12:50 PM   #4368
georgehifi's Avatar
Must be Scottish Heather, read my statment again, it's the NSL32SR2S I'm refering to because it has a much lower "R on" resistance than the other two, go and take another shot of single malt, that Heather must hurt. ouch!!!!!!
Cheers George
Old 7th January 2012, 09:09 PM   #4369
I've never seen a log pot that produced that curve. All are approximations. It's not terrible, I mean, we've all happily lived with pots for years. But it just seems to me that if you're trying to get away from pots with the LDRs, well, then you would get away from pots.
Not to be nitpicky - I realize your goal is to keep the mechanical wiper out of the signal path. The actual curve of the pot is probably well less of an issue to you. But it does seem to me like part of the problem inherent with mechanical potentiometers is still there.
Old 7th January 2012, 10:27 PM   #4370
georgehifi's Avatar
As you may/may not know the pot has nothing what so ever to do with the LDR's or the incoming or outgoing music signal, and with this design the sound quality has always come first.
All it's there for is to control the amount voltage going to the LED's in the simplest, cheapest most convenient manner, if you have a simpler way I'm all ears, KISS.
Cheers George
Copyright 1999-2017 diyAudio
