| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#421 |
Looking at it, looks like it should work fine. Guess I spent all those hours digging through surplus bins for dual linear 100K pots for nothing. Single pots are much easier to source.
Everyone but me seems to have used log pots. I find the taper works fine with linear. The reason is because the shunt and series move in opposite directions, so the result is a second order function. If a fixed shunt and variable series element was used the taper would require a log pot. Just picked up new pots today, passed up a BUNCH of high quality cheap single pots. Guess it is back to surplus soon. George
Cheapest is bestest |
#422 |
This looks good, though I think you would have to use a 200k log pot as the entry of the 5vdc is now at the centre of the rseistance track.
Keep it up guys this is good thinking. As for using a linear in my setup it comes on too quick, a log is just right, but with this single setup who knows you'll just have to suck it and see. BTW. I think the sound will not change at all, but the feel of the volume control's advance will, and also it would make it a dollar or two cheaper to build. Cheers George |
#423 |
Lightning In A Bottle
Thanks, George (Panelhead).
George(hifi), attached is a schematic of the LSA...let me know if I missed something...Thanks for sharing!
Quad Matched Toshiba 2SK1530/2SJ201 MOSFETs http://www.diyaudio.com/forums/swap-...ml#post2086375
#424 |
Here's the one with a Single Pot...
#425 | |
Cheers George (Nice drawing BTW). |
#426 |
would this schematic work for balanced input?
#427 | |
Can I ask what is the advantage with this arrangement "I only had it coming in on one end of the resistance track of each section and not the wiper as well"? |
#428 |
You posted a different zipped one 3 posts back, I think you made a booboo.
And this last one I think you may have to use a 200klog pot Cheers George |
#429 |
This single pot balanced version should work nicely, again with a 200klog pot, wish you all the luck on the matching of the LDR's double the work.
Cheers George |
#430 |
Disregard my thinking about the 200k pot for the single version, my head wouldn't think straight about it, I think now as you it should be 100k as well.
Cheers George |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Page generated in 0.14485 seconds (64.13% PHP - 35.87% MySQL) with 11 queries |
