diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Analog Line Level (http://www.diyaudio.com/forums/analog-line-level/)
-   -   Have an offset for 2V with OPA2134 (http://www.diyaudio.com/forums/analog-line-level/63287-offset-2v-opa2134.html)
Progg70 27th August 2005 10:05 PM
If I have an OP with no possibility to adjust the output offset. How can I then have about 2V offset? Iím looking for a nice circuit solution. I have one OP for the input and another like a driver before the output stage. The Output stage need a offset for about 1.9V to have 0V on the output. I use the OP OPA2134.
regard
Progg70
BrianL 27th August 2005 10:12 PM
You need to give some useful information if you expect
help. At a minimun, a circuit diagram would be instructive.
Progg70 28th August 2005 06:40 AM
2 Attachment(s)
Good morning!
OK! I have now an attachment with the circuit. I need a offset for + 2V on the output.
Regard
Progg70
peranders 28th August 2005 02:21 PM
If you have an AC coupled output you won't get any offset at all.
If you tell us the application it may be easier to understand what you are after.
Progg70 28th August 2005 04:10 PM
2 Attachment(s)
OK! My mistake! You can skip the capacitor at the end, they was there from the beginning.
So, the output is the DC-coupled and I need to have the audio signal +2V offset.
The output signal is going to have about 20V top-top. If someone can tell me a nice configuration to adapt to this circuit Iím really happy.
Regard
Progg70
wa2ise 29th August 2005 07:17 AM
To create a +2V offset on the output, move the 10K resistor R6 from ground to a clean source of -3/4 volt. What this does is to draw current from the output, thru the 27K feedback resistor, and then on to the 10K resistor to the -0.75V supply. The op amp's inverting input is kept at 0V, and thus the output willo to +2V. The audio signal is amplified as before. This is essentially an adder circuit.
Progg70 29th August 2005 01:31 PM
Tanks! Exactly what i needed.
Iím going to try it in the afternoon.
Now I hope my small single end-amp. will bee ready for a first test to the weekend.
Regard
Progg70
Progg70 30th August 2005 06:19 AM
Yes!
Yes!
Itís working very nice. I have de circuit ready now so Iím starting with the PCB.
Progg70
Resources saved on this page: MySQL 18.75%
