Low level interconnect (RCA) measurements - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 8th August 2014, 04:00 PM   #21
Kastor L's Avatar
Send a message via ICQ to Kastor L
Originally Posted by Conrad Hoffman View Post
Kastor- yes, I tested some Teflon aircraft coax. Fantastic stuff on the waveform, also has a dissipation factor of 0.00002, though moderately high capacitance.
Is it a perfect looking square-wave with a little peak at the edges?
SKY reference
Old 8th August 2014, 04:03 PM   #22
Pano is offline Pano  United States
Pano's Avatar
Nice test Conrad, thanks for posting.
I'm thinking the difference is mostly L.
Who's better at Spice sims than I? Should be easy to simulate your tests in Spice and see what varying L would do to the the waveform, right?
Take the Speaker Voltage Test!
Old 8th August 2014, 04:45 PM   #23
merlin el mago's Avatar
I think I mentioned that, as mica caps are the example always used for very low DF with surprisingly high DA. It's true, but that "high" DA is in comparison with better dielectrics and my guess is it isn't even on the map compared to the stuff they make cables out of, with the exception of Teflon. Or, maybe it only shows up in a different frequency range. I don't know if DA is entirely predictable once you have a single point measured. When I get back to the scope I'm going to add an air variable cap to the other input. Then I can null the square wave, increase the gain, and see much more subtle differences. My guess is I'll be able to see the DA of the mica cap then. I need to find a similar value NP0 to compare- I have about 8 billion components here, but never the right values! Have you ever seen a 68000 pF silver-mica? I have one. 270 pF or similar NP0? Not a one!
The reason I like differential measurements so much is they show errors regardless of cause, then the fun is explaining them.
RFMICROWAVE | CMA-6N8 | Horizontal silver mica capacitor 68 nF 5%
Old 8th August 2014, 06:20 PM   #24
Elvee is offline Elvee  Belgium
Elvee's Avatar
BTW, anybody with a scope can, and should, duplicate this test. Almost all two channel scopes will let you invert one channel and then sum them (A+B mode), giving you a differential amplifier. Find a couple matched resistors, a function generator and Bob's your uncle.
It won't work that way, because the vertical channels saturate at ~200% of the full scale deviation, and with a 5mV/div setting, the stimulus couldn't exceed 100mV very much which would be mostly useless, but fortunately there is an even simpler way: just put resistor between one input and the ground, and feed your generator through the DUT.
Basically, you create a differentiator of which the DUT is the reactive element.
The inconvenient of this arrangement is that no side of the DUT will be grounded, but this shouldn't be a problem since generators have a low output impedance, typically 50 ohm.
Regarding the results, they may look spectacular (and some spectacularly bad), but in fact they aren't:
Firstly, what we see is a purely linear effect: it has no impact on linearity. It is a component of the dielectric losses. You can call it dielectric absorption, or something else, it doesn't really matter: DF and DA are no two different things, DA is just a component of the DF expressed in a convenient form.
DA is not limited to long time constants: it comes under various forms. In french, one of them is called "traînage", I think the translation could be "streaking".
This type of phenomenon is typical of heterogeneous materials or cable construction: it could be due to a particular filler of the polymer, or to multiple materials in the cable: wire insulation, strands of textile as fillers, strands of polymers for mechanical resistance, overall insulating wrap, foil shielding:
Chances are that low-microphonic cables are particularly "bad" in this respect...
Secondly, the effect is not only very small, but to have any impact, it would require large source impedances, and even then it would manifest itself as variations in the gain vs frequency smaller than for a "good" cable of similar capacitance.
Thirdly, the characteristic impedance of cables (even the very best ones) at audio frequencies is nowhere near "clean": the argument of the impedance is close to -45° and variable with frequency, and the magnitude also varies with frequency
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 8th August 2014, 08:18 PM   #25
Elvee, I'm afraid you're right about scopes. The common mode range isn't great enough, unlike the dedicated differential plug-ins. There are some op-amp circuits with huge common mode range (an ancient National app note comes to mind) but there may be a noise price with the large values they use. Still, if somebody were interested enough, they could make an op-amp diff amp for the test.
As for the rest, I feel somewhat like the blind man trying to describe an elephant by the feel of its leg. I simply don't have enough knowledge about how some of the parameters interact.
DF and DA are certainly related, but I'm not convinced they're always the same thing. DF is an energy loss- for every cycle you get back a little less than put in, and the difference is dissipated as heat. DA, or "soakage", doesn't necessarily imply that you don't get the energy back, it just takes more time. OTOH, DA is modeled using multiple RCs in addition to the main one, so maybe the loss is real for that too.
The problem with trying to model any of this stuff is that standard cap models are only good for a single frequency. In the same manner I can null a capacitance bridge on a high DF and DA part at a single frequency with no problem. DF is frequency sensitive, so the bridge balance will change with frequency. That's also the flaw in the Jung capacitor null test- the DF couldn't be nulled out over frequency.
I don't understand how you can say the error is linear. If it were linear or proportional the square wave would simply have some tilt, but never the form shown with the "bad" cables. I do agree these effects are not huge, but at the same time, something must account for different sounding interconnects. Unless there are no different sounding interconnects! I'm pretty sure I can round up two groups, believers and not, just as it's been for decades! Heck, we were arguing about this back when I was in college in the '70s.
Regardless of the magnitude, audibility and reasons behind it, the test does show the difference between the signal that should have arrived, and the signal that really did. Given a choice, I'd go with cables having less error.
Interestingly, the Monster cable has the most complex construction, with twisted fibers and the conductor wound around a clear plastic core, and performs well (because of it, or in spite of it) and the "bad" cable has the most basic coax construction, with a single simple dielectric.
I may be barking up the wrong tree, but at least I'm barking!
Old 8th August 2014, 08:35 PM   #26
The differential input test is the same as was in the AudioXpress article 11/09 Distortion meter. There the readout was using an AP System 2 FFT and a custom built differential input and a two tone low level signal. Now to trade cables and see if the results track.
There have been others who also have looked across the cable to see what happens.
Old 8th August 2014, 10:15 PM   #27
Elvee's Avatar
You are right: they aren't exactly the same thing: DA is included in DF (or cos φ and similar global parameters), but it doesn't include parameters like the actual series resistance (not the ESR, which is also global)
No, the process does imply a loss: if you charge any capacitor through any resistor (or resistive-like process), you have to invest an energy equal to CV˛ to recover CV˛/2 at best. Since in this case the processes of charging and discharging will both create losses, things will be worst.
Yes, and that model is useful for another reason: it shows that there are an infinite number of time-constants, ranging from the highest (generally classed under DA denomination) to shorter ones (dielectric losses in general)
The problem is that the ε of the dielectric is not a simple arithmetic value, but a complex number. If that is taken into account, most of the difficulties disappear (factors like the ohmic resistance remain)
It is linear in the usual meaning of the term: the relation between the input and output amplitudes is constant, ie it does not generate harmonic or intermodulation distortion. It only changes the amplitude/phase vs frequency response.
If you use a pure sinewave instead of a triangle, you will (almost) not find other frequencies in what you measure
That is a completely different debate....
I am not sure about your exact test configuration: did the signal actually pass through the DUT? (I don't think so) A schematic would help.
If the signal actually passed through the DUT, then what you consider as "bad" cables are actually the best, because for a given capacitance they give the less average error
Quite surprising, unless of course the dielectric of the bad cable is not the usual PE or PTFE stuff of coaxials but some spiked PVC or similar
Old 8th August 2014, 11:10 PM   #28
john curl's Avatar
The Jung Capacitor test still holds up. We were testing for differences, not hoping for a perfect null. When the DA is low, the null is almost perfect.
"Condemnation without Examination is Prejudice"
Old 8th August 2014, 11:15 PM   #29
Kastor L's Avatar
The cable difference looks like it's affecting the transient response, not amplitude or frequency response.
It's like an amplifier, all perfectly flat with varying transient response, at least that's what it looks like in this case, since the DA transition is causing a non-uniform electron displacement.
SKY reference
Old 8th August 2014, 11:42 PM   #30
SY's Avatar
You apparently haven't taken the suggestion from numerous people to learn the basics of Fourier analysis.
This is gibberish.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Interconnect cables (RCA) mfspdesigns Vendor's Bazaar 2 8th May 2014 03:58 PM
RCA interconnect with Cat5 ? gychang Everything Else 23 10th August 2013 03:59 PM
RCA interconnect configuration KCC Everything Else 4 19th January 2008 01:13 AM
RCA into XLR interconnect Idea Brian Donaldson Everything Else 12 30th August 2005 05:59 PM
HOWTO: High/speaker to low-level/RCA converter ??? bbaker6212 Multi-Way 2 10th September 2002 06:04 PM
Copyright ©1999-2017 diyAudio
