Hello
Any possibility of using this good hardware for remote controlling and input selection.
You could buy a remote controlled linear pot and use that with this board but you would still need another separate board if you wanted channel switching.
Also, this specific attenuator version has not been available for several years.
The current up do date and final version is V3 :
Pop/click free HW-based relay attenuator V3
I did something similar with volume, input, mute and an IR remote, all digitally controlled. I used through hole as it is easier for the average DIYer to build and yes it is a little bigger. Hardware is easier to build and troubleshoot than a MPU. Check it out.
Home > Forums > Source & Line > Analog Line Level Preamp Control -Volume,input,mute, remote
