Go Back   Home > Forums > Source & Line > Analog Line Level
Old 10th December 2012, 08:03 AM   #2351
Originally Posted by PHEONIX View Post
Do you have a copy of Dimitri's "Enhanced cascode Article".
I don't Pheonix. I'm new to diyaudio. A link would be appreciated or a PM. Thanks
Old 10th December 2012, 09:06 AM   #2352
aparatusonitus's Avatar
Send a pm with your email and I'll pass the article.
Non é mai abbastanza...
Old 10th December 2012, 10:03 AM   #2353
Send a message via Yahoo to linuxguru
Originally Posted by luvdunhill View Post
Interesting, I'd like to play with this one as well, if that would be okay. I could probably even do a two sided version in a SIP-8 dual opamp format, similar to my layout. I could volunteer to look at higher output bias version.
Sure, you're welcome to try out anything. I'm guessing that a high-bias version that's able to drive low-Z loads will require through-hole TO-92 or TO-126 output devices, and the board size is a constraining factor. Presently, I'm at 14mm x 14mm using the Rohm IMX2/T2 duals, and the 2sk209 singles. I was able to route everything on one layer without vias, but had to remove pads 1 and 5 from the DIP8 footprint to create space.
It is conceivable that a 2-layer SMD DIP8 dual opamp is within reach, but it will be slightly larger because pads 1 and 5 are required.
Old 10th December 2012, 01:43 PM   #2354
luvdunhill's Avatar
one last question. I'd like to optimize an incarnation for use in Salen-Key filters. Is there a good rule of thumb in terms of load that approximates a wide variety of filter topologies? I was thinking that something in the 30K range would be normal (with a spike where you'd expect it) and was using 4.7K in my simulations. I thumbed through Self's book on the subject last night and didn't see anything in the opamp section where he goes through a bunch of current parts and discusses their relative merit. I have a feeling this answer is more difficult than what I'm asking for, but go easy on me
Old 10th December 2012, 03:24 PM   #2355
Does anyone have a recommended complementary SOT223 device?
I'm using 2SC5964 and 2SA2125 as they are the highest power rated devices in this package I have found so far and also have a huge Ft and decent Hfe but I don't know how advantageous any of this is. See some others from my list (all SOT223)
2STN1360 2STN2360 60v 3A 1.6W 130MHz 80 400
BCP55 BCP52 60v 1A 2W 150MHz 100 250 linear to 100mA, designed for AF
BCP56 BCP53 80v 1A 2W 150MHz 100 250 linear to 100mA, designed for AF
BCX55 BCX52 60v 1A 1W 150MHz 100 250 linear to 100mA, designed for AF
BCX56 BCX53 80v 1A 1W 150MHz 100 250 linear to 100mA, designed for AF
FTZ692B FTZ792A 70v 2A 2W 160MHz 300 800 linear to over 100mA
FTZ651 FTZ751 60v 3A 2W 140MHz 100 300 linear between 10-200mA
Old 10th December 2012, 08:59 PM   #2356
Output THD @ 20kHz (according to LTSpice)
I'm sure you adjusted resistor values so you compared the transistor pairs at the same collector idle currents.
I still don't have a good intuitive feel for the parameter interactions in the cross-coupled output stage of SW-OPA (see atch image)
Click the image to open in full size. .
I recall reading somewhere that the output drivers (Q14 and Q58 in Post #1568) should be faster than the actual output devices (Q56 and Q69) for frequency stability. But for lowest distortion (and perhaps thermal stability) the seat of my pants says they should be the same as the output devices.
Rather than looking for output devices that minimize distortion, should we be looking for pairs that work best in this topology, i.e. consider the compound-connected Q56/Q58 (and Q14/Q69) as single devices to be optimized?
Dale
Old 12th December 2012, 01:13 PM   #2357
This pair is also available in SOT89, smaller than SOT223, and with metal tab.
Old 12th December 2012, 02:16 PM   #2358
scott wurcer's Avatar
Dale
It's really just a diamond that bootstraps itself. Any stability issues would mainly be with Q14 and Q58 looking back into the emitters of the output devices which can look inductive as you approach Fbeta. The output stage breadboard had no problems, and at 8mA bias and 600 Ohm load still only had .01% distortion.
The Sziklai pair has feedback and in my experience is much more prone to oscillate, but the added gain typically reduces the distortion by a larger factor.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 12th December 2012, 03:52 PM   #2359
bcarso is offline bcarso  United States
My experience as well with Sziklai. And the poorer ability to turn off an output device translates into a dynamic asymmetry that is somewhat bothersome at high frequencies. Bryston has used a triple compound that they have managed to make work, but it looks very temperamental in simulation.
Old 12th December 2012, 03:56 PM   #2360
Look at signal-to-noise at a given frequency to determine how sensitive it will be to impedances, and then make the determination about how the filter components will load the amp output. Then fold in the loading thereafter.
Every situation is different, and I know of no rule-of-thumb. Lower Z is always lower noise, but depending on where the circuit is in the system you may be well-dominated by noise in the input signal already, so there may be no reason for heroic measures in the filter.
Discrete OPAMP audio-gd Vendor's Bazaar 27 20th September 2012 04:02 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Page generated in 0.18258 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
